Old 01-08-2021, 09:22 AM   #1
flathead48
Default Block id
Did any 24 stud blocks with 3 &3/16 bore have just a large letter 5 on top of
Bell housing
Thanks
flathead48 is offline   Reply With Quote
Old 01-08-2021, 09:45 AM   #2
corvette8n
corvette8n's Avatar
Default Re: Block id
Rick: Info from Van Pelts website, maybe the 9 didn’t get stamped for some reason, can you use the pictures to ID the block?
File Type: jpg 1A0073A7-5CA0-480E-91D2-B4A2666CD589.jpg (93.7 KB, 33 views)
Old 01-08-2021, 10:24 AM   #3
flathead48
Thanks Bob , haven’t seen the engine yet . Will go this weekend.
Happy New Year ,
Old 01-08-2021, 10:27 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
The large raised numbers are part of the sand casting process and I suspect that it is a defective casting,
It could probably have been just as well the number 9 that was left after the 5 was wiped off the sand mold.
