12-28-2020, 07:47 AM | #1 |
Using magnets instead of holes
I know a lot of owners are opposed to drilling holes to mount accessory things like the flasher for turn signals. Me too. I learned a new trick, for me anyway, when I bought my present car. The previous owner had used magnets to mount devices. High power magnets can be bought on the internet. I buy mine from McMaster Carr. They have ones that are coated so that they do not scratch the surface. Or tape can be put on the ones that are not coated. I glue them onto the devices I want to mount on the firewall or on the bottom of the fuel tank or elsewhere. I use a silicone or epoxy adhesive depending on the device.
I have used double sticky back tape in the past but that leave a residue when removed. Plus, the magnets allow the devices to easily be removed for service or re positioned.
12-28-2020, 07:56 AM | #2 |
Re: Using magnets instead of holes
very intelligent, thank you. I had never heard of anyone else doing that!
12-28-2020, 08:47 AM | #3 |
I know a Fordor owner who used 4 rare earth magnets to mount his dome light temporarily because the wood needed to be replaced , a future project. Imagine the surprise when something stuck to the outside of the body when it got to close.
12-28-2020, 09:00 AM | #4 |
I’ve successfully used magnets like this to mount a terminal buss for my turn signal connections in my Victoria.
https://www.lowes.com/pd/Hillman-3-4...Magnet/3115767 No problems so far. Sent from my iPhone using Tapatalk |
12-28-2020, 10:43 AM | #5 |
Yes, I used a phone magnetic device to hold the GPS onto the dash.
It is DS taped to the GPS and the mag has an adjustable joint/ball to make the screen easier to read. Available on amazon for under $10 J
As Carroll Smith wrote; All Failures are Human in Origin. |
12-28-2020, 11:56 AM | #6 |
If u care |
12-28-2020, 12:03 PM | #7 |
Can the magnets conduct electricity to an unpainted surface?
12-28-2020, 12:12 PM | #8 | |
12-28-2020, 12:15 PM | #9 |
I have used magnetic wire fastners throught out my car and have been very satisified with the results, no need to drill holes. They come in several sizes and are a bit pricey but work well. I get them from Speedway Motors.
https://www.speedwaymotors.com/Mag-D...ack,80882.html |
12-28-2020, 12:18 PM | #10 |
I like your gear shift knob, it's the little fun things that make your car, your car.
12-28-2020, 02:00 PM | #11 |
12-28-2020, 04:05 PM | #12 |
I've used Velcro both on the bottom of the gas tank and the firewall to mount things.
12-28-2020, 04:18 PM | #13 |
I've been doing this for years. As for double sided tape leaving residue when it is removed, try using a little mineral Turpentine on a rag. I put button magnets on all of the oil drain plugs too.
12-28-2020, 04:50 PM | #14 |
For fender covers, I use bath towels, held in place with rare earth magnets. Also have one in the sediment bowl to pick up contaminants.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
12-28-2020, 05:12 PM | #15 |
12-28-2020, 05:46 PM | #16 |
12-29-2020, 12:23 AM | #17 |
Yes that is what i was asking. There may be some voltage drop I expect. Thinking I may be able to add turn signals with only one physical wire.
12-29-2020, 05:48 AM | #18 |
I wouldn't trust a magnet to hold a turn indicator light on. It will end up on the road, for sure - or in someone's pocket.
12-29-2020, 07:37 AM | #19 |
It depends on the material of the magnet. If it is an alnico magnet, which is all metals, it will conduct electricity. It it's a powdered ferrite magnet, it will not conduct electricity - at least not very well.
12-29-2020, 12:07 PM | #20 |
If you want to experiment, get a magnet with a pre-threaded hole. Rare earth magnets are typically brittle and can't be easily drilled or tapped.
Thread Tools | |
Display Modes | |
