Old 09-06-2019, 04:36 PM   #1
Afordman31
Afordman31's Avatar
Default Ignition points
Anyone have a cross reference for breaker points for 1937 to 1940 Ford distributor? Wondering if I can get them local. Thanks
Afordman31 is offline   Reply With Quote
Old 09-06-2019, 05:31 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: Ignition points
37 to 41 Ford V8 is CS47 Echlin at Napa Auto Parts.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 09-06-2019, 10:01 PM   #3
Afordman31
Afordman31's Avatar
Bruce
Thank you Bruce, much appreciated!
Old 09-06-2019, 11:13 PM   #4
35fordtn
35fordtn's Avatar
Standard owns echlin and the standard Motor products number is Fd6770. Usually available at any big chain store
35fordtn is offline   Reply With Quote
Old 09-07-2019, 07:40 AM   #5
Afordman31
Afordman31's Avatar
Thank you also! 35fordtn
Old 09-07-2019, 08:42 AM   #6
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Got to be carefull with the change in Standard , the actual standard point set can be a cheaper set of contacts. Standard offers a couple grades of points and the lower set is NOT the Echlin set. I buy these 10-12 sets at a time from napa and often have to return the cheaper (standard) set for exchange to the Echlin all in the same box...
The Echlin set has a double spring arrangement with a brass strap and a spring . The cheaper set doesnt usually have the brass strap , just a steel spring by its self.....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 09-07-2019, 09:04 AM   #7
35fordtn
35fordtn's Avatar
Jim currently standard only has the standard line, the days of cheap blue streak are gone. I too had to return some echlin sets due to weak spring tension. Since I have been using standard Fd6770 I have NEVER had to return any. We sold and used 54 sets this month alone. This all tells me it’s a echlin issue not a standard issue. A good set of fd6770 and a good set of cs47 both have the same spring tension. The only issue with some of the older stock 6770’s is the LH stationary point needs to be adjusted (bent) slightly. That’s my opinion only, the echlins I bought at my Napa were not satisfying to me and seemed to be old stock. I buy the 6770’s from rockauto.com,
Old 09-07-2019, 03:06 PM   #8
BUBBAS IGNITION
WOW two different worlds i guess , my local supplier still offers some blue streak (lower priced) stuff and i just yesterday afternoon picked up a few boxes of the CS47s ( from napa)that were reboxed Standard stuff...
i really understand the reasoning as i have worked for both companies over the years as a rep and trainer as well..... Anyway my orginal point (which seems pointless ) for this post still stands "be carefull""""...
I will call you first of week as i need some parts.....
[email protected]
Old 09-07-2019, 03:41 PM   #9
35fordtn
35fordtn's Avatar
Ahh I see blue streak is still around!! Maybe there are accidentally slipping some blue streaks into echlin boxes?
Old 09-07-2019, 03:44 PM   #10
BUBBAS IGNITION
"Grass hopper" you need to listen to us old guys more often.......
[email protected]
Old 09-07-2019, 11:56 PM   #11
35fordtn
35fordtn's Avatar
True that but I’ll still stand behind standard products in the red box, NOT the blue box.
