Old 10-19-2016, 11:32 AM   #1
shaefer
shaefer's Avatar
Default Silicone needed when installing new intake/manifold gaskets?
Picked up a new gasket kit from snyders (http://www.snydersantiqueauto.com/gasket-set-2006).
Wondering whether the exhaust/intake manifold gasket needs silicone or is it ready to go just the way it is?
I was born in 1982 and in 1989 my father found the perfect '31 Cabriolet. In 1997 he finally bought it and it became our favorite thing to do together. While my friends were buying Playstations and XBoxs, I was saving up for a muffler. 9 years later, while their game systems were gathering dust, I was picking my wife up for our first date in that car. I drive it to this day and I hope to keep it up so my son can enjoy it just the same. That's the joy of a Model A!
shaefer is offline   Reply With Quote
Old 10-19-2016, 11:36 AM   #2
Mitch//pa
Default Re: Silicone needed when installing new intake/manifold gaskets?
No sealer needed
Old 10-19-2016, 11:37 AM   #3
shaefer
shaefer's Avatar
Forgot to ask also about the radiator/water inlet gasket.
Old 10-19-2016, 11:40 AM   #4
tinkirk
tinkirk's Avatar
install dry or maybe with a little spray sealer
tinkirk is offline   Reply With Quote
Old 10-19-2016, 11:53 AM   #5
shaefer
shaefer's Avatar
10-4. Thank you!
Old 10-19-2016, 11:54 AM   #6
Mitch//pa
No sealer needed
Old 10-19-2016, 12:16 PM   #7
Brian T
Brian T's Avatar
I would not use that green gasket that's in that set, you will be replacing it in a short while, get the steel gasket or better still the copper gaskets.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 10-19-2016, 12:22 PM   #8
C26Pinelake
You can't go wrong with the copper gaskets. Do it right the first time. Wayne
C26Pinelake is offline   Reply With Quote
Old 10-19-2016, 01:34 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
OLD Race Car Builders say, "What the hell did we do in the "OLD DAYS", without MODERN sealers"?
Bill Stick
"THE ASSISTANT GURU OF STUFF"
Old 10-19-2016, 01:48 PM   #10
SeaSlugs
SeaSlugs's Avatar
I sprayed my copper ones with coppercoat - figured it cant hurt. Been spraying all gaskets with that stuff and seems to work well.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 10-19-2016, 04:44 PM   #11
Y-Blockhead
Y-Blockhead's Avatar
Just ask yourself, "If I'm using a gasket to seal the connection do I really need a sealer to seal the gasket?"
Old 10-19-2016, 05:13 PM   #12
Phred
Phred's Avatar
Confirming Brian T's comment.
I have seen the the green unclad manifold gaskets fail after a short amount of time.
I am also skeptical about how well any silicone would hold up with the extreme temperatures at the exhaust port.
I have had good luck with both the steel clad and copper clad gaskets. The copper clad are my preference.
Hope this helps
Phred is offline   Reply With Quote
Old 10-19-2016, 06:52 PM   #13
RUNNERBUN
RUNNERBUN's Avatar
Do not use silicon anywhere near the fuel system. Fuel will dissolve/soften silicon and cause you some heartache.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 10-20-2016, 02:11 PM   #14
dpson
dpson's Avatar
I heartily agree with the comments about the green manifold gaskets, also pass on the one piece dimpled steel gasket, they don't fit right. Pay a little more and get the copper clad copy of the original. Ask me how I know!
dpson is offline   Reply With Quote
Old 10-20-2016, 04:24 PM   #15
Tacoma Bob
Tacoma Bob's Avatar
Go easy when tightening the rad inlet. Many have snapped the ears right off. I learned here long ago many prefer a VERY light skin coat of "cone" instead of the gasket.
Tacoma Bob is offline   Reply With Quote
