Old 10-19-2015, 05:07 PM   #1
sphanna
sphanna's Avatar
Default 16-17-18 inch wheels and tires
I would like to learn what possible wheels to use for the new radial tires. I do not have the rims yet and request to know what you knowledgeable barners would recommend. Perhaps I will stay with the 19 inch if I can get radial tires for them. But I am looking for a smooth safe comfortable ride for my touring 1930 Fordor. I have heard that some modifications are required to make some of the 32-34 wheel changes. Anything I need to know beyond just replacing the 19's with the newer wheels?
Thank you for any input on this.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 10-19-2015, 05:21 PM   #2
CarlG
CarlG's Avatar
Default Re: 16-17-18 inch wheels and tires
Originally Posted by sphanna View Post
I would like to learn what possible wheels to use for the new radial tires... Perhaps I will stay with the 19 inch if I can get radial tires for them...
Check out Coker tire Excelsior Stahl Sport Radials. They make them in 19".
Check out this thread: (especially post #24)
http://www.fordbarn.com/forum/showth...t=radial+tires
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-19-2015, 05:45 PM   #3
Charlie Stephens
What modification are you hearing about? To the best of my knowledge they just bolt on. You may have to let some air out for a fender mounted spare (and carry a tire pump).
Charlie Stephens
Old 10-19-2015, 06:12 PM   #4
sphanna
sphanna's Avatar
I thought I heard that inorder to keep the wheel from rubbing somewhere, that a spacer or washer or something had to be added.
Old 10-19-2015, 06:19 PM   #5
CT AV8
CT AV8's Avatar
Charlie, the one thing I recently read about here is the lug nuts should be swapped for B-1012 ('32-'48) when using '32-'35 wheels on a Model A. The taper is different and it allows better fitment. I've run the original A-1012 nuts with my 16" wheels for many years and haven't had any problems, but it seems like a good idea to change them. It's cheap and easy to do.
CT AV8 is offline   Reply With Quote
Old 10-19-2015, 06:21 PM   #6
CT AV8
CT AV8's Avatar
No spacer or washer required for '32-'35 wheels on Model A.
Old 10-19-2015, 06:27 PM   #7
sphanna
sphanna's Avatar
CT AV8: Yes, now that you jogged my memory, that is what I heard that the lug nuts needed to be changed in order to not have the tendency to crack the wheels at the lug nuts.
Last edited by sphanna; 10-19-2015 at 07:39 PM. Reason: Miss interpreted user name
Old 10-19-2015, 06:29 PM   #8
sphanna
sphanna's Avatar
I really appreciate the answers I received. It looks like the way to go is to go with the 19 inch wheels. Just wondering now if I can use my tubes or do I need to purchase special tubes for radials?
Old 10-19-2015, 06:30 PM   #9
CarlG
CarlG's Avatar
It also depends on if it has been changed to Hydraulic Brakes. And what kind.
Alaskan A's
Old 10-19-2015, 06:51 PM   #10
sphanna
sphanna's Avatar
Standard mechanical brakes, Flat Head Ted
Old 10-19-2015, 08:28 PM   #11
Charlie Stephens
Good point. Also a problem would be if the studs are too long the Model A lug nuts would bottom on the stud before the wheel.
Charlie Stephens
Old 10-19-2015, 08:32 PM   #12
steve s
steve s's Avatar
Talk to these guys:
http://www.mtcarproducts.com/index.html
steve s is offline   Reply With Quote
Old 10-20-2015, 10:46 AM   #13
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I had 17 inch wheels on my roadster and they rode really well. I found the size to be closer to the 19s and more space between the spokes than the 16 tor easier cleaning. No spacers were needed but they were a pain to mount because you couldn't eyeball the stud locations when mounting.
Barry B./ Ma. is offline   Reply With Quote
