Old 09-22-2015, 06:30 PM   #1
Darrell S
Darrell S's Avatar
Default 48 transmission mount
What is entailed in replacing the transmission mount on a 48? I know the front mounts are dry and hard as is most of the rubber underneath. I would like to cut down on clutch chatter.
Darrell S is offline   Reply With Quote
Old 09-22-2015, 06:54 PM   #2
George/Maine
George/Maine's Avatar
Default Re: 48 transmission mount
Remove the 2 nuts and if you have the stock bolts with the square head push them up and out. Then jack the trans 1 or2" to get the mount out.
George/Maine is offline   Reply With Quote
Old 09-22-2015, 09:50 PM   #3
Drbrown
Drbrown's Avatar
Take care to not over-tighten the bolts.
Drbrown is offline   Reply With Quote
Old 09-23-2015, 08:59 PM   #4
Darrell S
Darrell S's Avatar
Thanks for the information. Lots of these types of questions are basic to you Seniors but there is a wealth of useful tips for a newbie like me.
Old 09-24-2015, 03:17 PM   #5
supereal
supereal's Avatar
The rear engine/transmission mount usually doesn't contribute much to the usual clutch chatter unless it is broken or oil soaked. We usually put a grease fitting extension on when we replace that mount, as it can make getting a grease gun on the fitting difficult without it. The annoying clutch chatter is a legacy of the original design which was first used in the Model T days and continued thru 1948. Old Henry Ford was fanatically opposed to change of any kind, and used the buggy spring/torque tube system long after it was obsolete. His resistance to his son's (Edsel) designs almost cost him the company when the Model A was proposed. He went so far as to have a new '39 converted to mechanical brakes because he didn't trust the hydraulics used on his competitor's vehicles. His successor, Henry II, saved the brand with the "new" Ford of 1949. Those of us with great affection for the early Fords just live with the chatter, for the most part.
supereal is offline   Reply With Quote
