Old 09-26-2013, 08:53 PM   #1
flatford8
flatford8's Avatar
Default '37 steering column and box
I dont have one of the books. Does a steering column and box interchange between car and 1/2 ton p-u. Thanks, Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 09-26-2013, 08:58 PM   #2
Rowdy
Default Re: '37 steering column and box
I think the hole for the column drop and the hole in the steering shaft is in a different place. Vince Faulter has dimensions chart on his website. Rod
http://www.fordgarage.com/pages/stee...twormchart.htm
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 09-26-2013, 09:09 PM   #3
37 Coupe
37 Coupe's Avatar
A different lock assy is used for 1/2 ton I think it was the 35 part # (48 prefix) same goes for the steering column tube the 1935.Steering gear on pickup is different ratio than passenger car but I think the housing was the same for cars and trucks.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 09-26-2013, 09:46 PM   #4
flatford8
flatford8's Avatar
Thanks for your help. I have a 37 p-u. With a bad column and box.Theres a 37 box and column for sale locally and wondered if it would fit. Its not restoration,i just want a driver. Thanks again, Mark
Billy Joe Shaver
Old 09-27-2013, 07:16 AM   #5
jerry grayson
NO, the box and the internal gears and bearings are the same 37-47 car and pickup. Some of the boxes have different details OUTSIDE, but will fit. Some years have different length steering shaft.
Flatford, you are good to go with your plan, but you may have to alter the location of the column drop and the locking sleeve on the shaft.
jerry grayson is offline   Reply With Quote
Old 09-27-2013, 07:40 AM   #6
37 Coupe
37 Coupe's Avatar
All my information I posted was from my 1937 Ford passenger cars and trucks Chassis parts list dated December 1936. It shows parts numbers for passenger cars prefixed #78 and parts for pickups are prefixed with the 1935 # 48. Also shows the different gear ratio. The column support/lock is definitely made just for the pickup dash bottom compared to the 1937 passenger car dash contour. The only item besides bearings that are the same is the housing itself as far as Ford part numbers.
Old 09-27-2013, 08:18 AM   #7
rotorwrench
rotorwrench's Avatar
Commercials usually have higher mounting angles & may have longer steeering shafts/columns. Bigger trucks are definitely longer.
