Old 10-27-2017, 03:12 PM   #1
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Brattons pistons
Anyone use brattons pistons, and do the listed .002”/.003” clearances work. The machine shop has a tight .002, and I’m nervous. Anyone know who makes them?
Old 10-27-2017, 03:36 PM   #2
George Miller
George Miller's Avatar
Default Re: Brattons pistons
.002 is to tight on 3 and 4. They will score and might seize in the cylinder. The old .001 per inch rule works well. Model A's do not have a water jacket all the way to the bottom of the cylinder. 3 and 4 do not get as much water movement as 1 and 2.
I would hone them to at least .0035
George Miller is offline   Reply With Quote
Old 10-27-2017, 04:42 PM   #3
Synchro909
Synchro909's Avatar
Right on, George.
Old 10-27-2017, 05:11 PM   #4
d.
call Brattons, they are helpful people.
d. is offline   Reply With Quote
Old 10-27-2017, 06:44 PM   #5
700rpm
700rpm's Avatar
.003 is too tight. My engine shop bored my cylinders to piston factory specs, which were .003. The engine seized up whenever it got warm. I pulled it apart and had it honed to .0045. No more seizing.
Ray Horton, Portland, OR
Old 10-27-2017, 06:47 PM   #6
Chuck Sea/Tac
Ray, where did the pistons come from?
Old 10-27-2017, 07:43 PM   #7
glenn in camino
glenn in camino's Avatar
I've always used Brattons pistons. I order one size larger if I'm having the block bored, and get the rings too
Old 10-27-2017, 09:25 PM   #8
Chuck Sea/Tac
But what is your piston to cylinder clearance?
The weird thing is I know a guy with 75 engines with brattons pistons with .002” clearance, and no problems. Yet others have seizures. There has to be something that’s different.
Old 10-28-2017, 10:32 AM   #9
briphaeton
Some newer pistons are---- Hypereutectic pistons are made of an aluminum alloy which has much more silicon present than is soluble in aluminum at the operating temperature. Hypereutectic aluminum has a lower coefficient of thermal expansion, which allows engine designers to specify much tighter tolerances.
briphaeton is offline   Reply With Quote
Old 10-28-2017, 11:25 AM   #10
George Miller
It maters how you check the clearance. Piston size and bore size will not give you a true reading. You need to have final check with feeler gauge, on the piston skirt.
Old 10-28-2017, 11:42 AM   #11
briphaeton
Using inside a micrometer and double checking the measurement with a outside micrometer works good enough for engine rebuilders. Outside micrometer are checked against a standard. I like my Intrimik mics for checking the bore but you can't use them while boring the cylinder.
Old 10-29-2017, 10:49 AM   #12
Jim Brierley
I agree with George, use a feeler ga. I bore to .003, then hone another .0005, much more on a racing engine.
Old 10-29-2017, 02:06 PM   #13
1930-Pickup
A good machinist will bore the cylinders to fit the new pistons...this will solve any issues of piston manufacturing tolerance variations. My machinist even makes sure to mark which piston goes to which cylinder.
If the clearance is too small on your motor after rebuilding it, it sounds like the machinist didn't do a good job.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 10-29-2017, 03:04 PM   #14
George Miller
I do the same, but you still need to do a final check with a feeler gauge.
Old 10-29-2017, 05:26 PM   #15
[email protected]
wjbgthom@mac.com's Avatar
The problem may not be the clearance. It may be the pistons.
A couple years ago I took some new pistons and a block to a machine shop for fitting. The machinist looked at the pistons and noticed the skirt of the piston was rather thin. He measured the piston, held it hot tap water for a few minutes and measured the piston again. The piston skirt had expanded over two thousands of an inch under hot tap water. He refused to use them. I bought some Silver-o-lite pistons, bored the cylinders 3 thousands over and have not had a problem.
Bryan Thompson
wjbgthom@mac.com is offline   Reply With Quote
Old 10-29-2017, 10:53 PM   #16
700rpm
700rpm's Avatar
Snyder's. BTW, George gave me the good advice about honing out to .0045. Thanks again, George!
