06-20-2016, 08:50 AM | #1 |
'51 door gap
I can't see a way to adjust the door gap on a '51 Tudor. Anybody have an idea? Thanks..... Mark
06-20-2016, 08:51 AM | #2 |
Re: '51 door gap
Sorry... The picture is sideways..... Mark
06-20-2016, 08:57 AM | #3 |
Re: '51 door gap
Not much help on the gap, but I can help with the photo.
06-20-2016, 09:20 AM | #4 |
Re: '51 door gap
Ha ha..... Thanks!..... Mark
06-20-2016, 09:56 AM | #5 |
Re: '51 door gap
If the gap is too tight. (can't really tell by picture)
On the door post side of the hinge, on the inboard screws place thin washers or 'U' shims between the hinge and the post. This moves the hinge point forward. The other way requires some massaging with a sledge hammer.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 06-20-2016 at 10:26 AM. |
06-20-2016, 10:40 AM | #6 |
Re: '51 door gap
06-20-2016, 10:54 AM | #7 |
Re: '51 door gap
flatfordV8: I have seen the following done.
If the A-pillars and floor are structurally solid and the door opens ,closes and latches without any "droop", carefully grind back the edge of the door and then reweld and finish grind and file the edge to the gap you want. It's not as scary as it sounds. "Tack weld and let cool. Tack weld and let cool. etc." However, try the shim idea first. Last edited by 19Fordy; 06-20-2016 at 10:59 AM. |
06-20-2016, 11:55 AM | #8 |
Re: '51 door gap
19 Fordy.. I thought if that but I knew I would open up the door skin. I may have to do both ideas because the door lip hits the body by the jam. There's no gap at all. The car may have been in an accident sometime in the past. Thanks for your help! ..... Mark
06-20-2016, 11:17 PM | #9 |
Re: '51 door gap
With the door open, try gentle application of a Porta-Power from the upper hinge area of the jamb to the door pillar where the clearance is tight. Go easy and keep checking the fit. Use some wood blocks to protect the metal. I have one you could borrow if you want to try this.
06-21-2016, 10:05 AM | #10 |
Re: '51 door gap
I tried a porta power and put as much pressure as I dared. Didnt seem to mive much..... Mark
