Old 05-21-2014, 08:18 PM   #1
expavr
expavr's Avatar
Default Ford Script Optima Battery Replacement???
The optima battery in the Ford Script battery case on my truck died. Has anyone taken the top off of the Script battery case to install a new Optima? Any words of wisdom would be appreciated. Thanks.
Les Williams
expavr is offline   Reply With Quote
Old 05-21-2014, 08:33 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Ford Script Optima Battery Replacement???
Yes. Look in the archives for a piece I wrote on that very subject three or 4 years ago, maybe longer.
Old 05-21-2014, 09:13 PM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
There is a good tech article on the EFV-8C/A, Northern Ohio Regional Group #20 website that gives details on how to install an Optima 6V Red Top Battery in a Ford script lead acid battery case. There should be some information in that article that tells you how to remove the top of that script case. Hopefully by clicking one of the two url's below, they will get you to that article....
http://www.norgv8club.org/norg/index...-docs-and-tips
http://www.norgv8club.org/norg/index...rd-script-case
John
Old 05-22-2014, 01:37 PM   #4
copperpenny
The one I just took apart has the Optima battery sitting in a solid mass of poured plastic...from a well known supplier of these "logoed" batteries. Wasted over $300+. How can you return the battery if still under warrenty?
copperpenny is offline   Reply With Quote
Old 05-22-2014, 08:17 PM   #5
steve-cook
steve-cook's Avatar
I have never owned an optima battery.
That being said I have read many recent reviews that are not positive on new optima batteries, it may be better to just replace with a script battery and use a battery maintainer to extend its life.
steve-cook is offline   Reply With Quote
Old 05-22-2014, 08:22 PM   #6
Bolts
Bolts's Avatar
I believe member Ford38v8 (Alan) did an extensive write up on putting the Optima battery in 6V case recently.
Nothing wrong with it except for the name on the front.
Alex
Bolts is offline   Reply With Quote
Old 05-22-2014, 09:25 PM   #7
ford38v8
ford38v8's Avatar
That I did, Alex.
http://www.fordbarn.com/forum/showthread.php?t=135661
Alan
Old 05-22-2014, 10:00 PM   #8
expavr
expavr's Avatar
Thanks for the input. I've decided to remove the bottom of the case using a modified approach shown in the PDF file from the Northern Ohio regional group. If Antique Battery who was the vendor that built it has filled the case with plastic, it may prove to be an exercise in futility. Regarding the actual Optima battery my experience was positive. It lasted 9 years which IMO compares favorably with a conventional battery.
Old 05-23-2014, 11:59 AM   #9
copperpenny
The "manufacturer" also poured new lead battery posts over the original posts. Brought their height up to better fasten the battery cables.They need to be sawed off flush with the top in order to remove the top completely.
Old 12-26-2023, 12:04 AM   #10
J Franklin
J Franklin's Avatar
Maybe it would be easier to turn it over and open the bottom side.
Old 12-26-2023, 03:22 AM   #11
ford38v8
ford38v8's Avatar
I wouldn't advise trying going up from the bottom in order to save the top. The top of the battery is thick, and needs to be replaced with as thin a material as possible for clearance of the height of the Optima, and to allow the Optima's posts to protrude. I used 1/16" ABS, with 3/16" atop that to simulate the 3 cells. Even then, for the LF case, the bottom will need to be removed, and a skirt of some sort will need to be fabricated to accommodate the increased height of the new version Optima, that skirt being of similar material (black ABS works well), and fastened securely and inconspicuously to the bottom, extending the height of the case. The skirt will not escape detection by a sharp judge, however, a neat job should not, in my opinion, draw a point deduction. Another method of creating a skirt would be to use a wood platform having a hollowed out core beneath the Optima, but again, this would not escape detection. The HF case will work without a skirt, but the exterior design pattern is way different than on the LF battery, and of course, was not available during the LF period, meaning an automatic point deduction on the Concourse.
Alan
Thread Tools
Display Modes
