Old 09-05-2020, 08:00 PM   #1
30-9
Default Tool question
Hi Gents
I like using my Dewalt impact with the adapter for sockets. Unfortunately the adapter continually brakes. Anyone have a good brand name that can handle the challenge of impact sockets on tough bolts and nuts?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 09-05-2020, 08:13 PM   #2
Zeke3
Zeke3's Avatar
Default Re: Tool question
Get an impact with the 1/2" square connection integral to the tool, it will be much more stout. In my experience, Every extra connection, either adapters or extensions, lowers the effectiveness of the tool.
I borrowed a friend's 1/2" Craftsman 18v impact and it broke loose the 1 3/8" bolt holding the crank pulley on a 1937 21 stud crankshaft. I was impressed.
Zeke3 is offline   Reply With Quote
Old 09-05-2020, 09:03 PM   #3
JSeery
JSeery's Avatar
I'm not sure what DeWalt uses, but my experience with air impacts is you need specific impact tools, as in impact adapters, sockets and extensions. The ones I have owned and used are a dull black finish.
Old 09-05-2020, 09:40 PM   #4
Ronnie
Ronnie's Avatar
Sounds like you are using an impact driver with a 1/4" hex drive. A cordless impact wrench is what uses the direct fit 3/8" or 1/2" square drive anvils with regular impact sockets. It appears you exceed the designed torque for the 1/4" adapter for sockets.Not really designed for heavy use.
R
Ronnie is offline   Reply With Quote
Old 09-05-2020, 09:47 PM   #5
JSeery
JSeery's Avatar
Originally Posted by Ronnie View Post
Sounds like you are using an impact driver with a 1/4" hex drive. A cordless impact wrench is what uses the direct fit 3/8" or 1/2" square drive anvils with regular impact sockets. It appears you exceed the designed torque for the 1/4" adapter for sockets.Not really designed for heavy use. R
Good point Ronnie, I was thinking a heaver drive. For smaller nuts and bolts they sell sockets that have the hex drive as part of the socket. Should work fine for lighter work. I have driven lag screws with my driver.
