Old 07-12-2020, 10:07 AM   #1
russcc
Default 180 Degree thermostat source
looking for a 180 degree Dole or Stant thermostat to fit the 59 style center outlet almn, heads. The ideal diameter would be 1 & 3/4", or 44 MM, (1.732). I bore the ID of the outlet to fit the OD of the thermostat. Thank you Fordbarners.
russcc is offline   Reply With Quote
Old 07-12-2020, 10:19 AM   #2
lotsagas4u
Default Re: 180 Degree thermostat source
Search Robert Shewman thermostats
lotsagas4u is offline   Reply With Quote
Old 07-12-2020, 10:27 AM   #3
RalphM
RalphM's Avatar
Napa
File Type: jpg 3BD7E026-599D-46A0-BA7A-DC4D72043A4B.jpg (23.1 KB, 38 views)
RalphM is offline   Reply With Quote
Old 07-12-2020, 12:04 PM   #4
Fordestes
I bought a pair from Van Pelts, Haven't installed the yet ,I like the shewman T stats.also.
Fordestes is offline   Reply With Quote
Old 07-12-2020, 12:09 PM   #5
Step-down
Step-down's Avatar
I used one from Subaru
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 07-12-2020, 04:34 PM   #6
Ford Freak
I did as well . However , I believe they are 170 's . Mine were anyways . - F F
Ford Freak is offline   Reply With Quote
Old 07-12-2020, 05:43 PM   #7
JSeery
JSeery's Avatar
The Subaru Justy is what is commonly referenced, but the same thermostates are used in several different makes, models and years. The normal reference you will see is Subaru Justy 1990. Should be able to get the temp range you want.
