Old 04-04-2020, 06:37 PM   #1
39fordgus
Default Carburetor issues 8ba
Hey everyone having issues on my carb it’s a 94 Holley carb Ford stamped on the body Im having issue keeping it to idle with the choke fully open if I close the choke half ways it turns on a higher idle once I start to open the choke more it dies I waited till the engine was warm and same thing. I opened and bought a rebuild kit because I was having that issue and something no carb expert by any means any advice will help thank you in advance
39fordgus is offline   Reply With Quote
Old 04-04-2020, 07:43 PM   #2
paul2748
paul2748's Avatar
Default Re: Carburetor issues 8ba
Sounds like a vacuum leak
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-05-2020, 06:13 AM   #3
Terry,OH
Terry,OH's Avatar
Could be the vacuum leak as mentioned above or blockage in the idle circuit of the Carb. Did you rebuild the Carb.? pay close attention to the air circuits in the Carb base. Daytona makes a good rebuilding kit. search for them on the web.
Old 04-05-2020, 06:42 AM   #4
jimvette59
jimvette59's Avatar
It could be the throttle shafts are very warn and sucking air. JMHO
jimvette59 is offline   Reply With Quote
