Old 08-27-2019, 11:27 AM   #1
walkerlakeprinter
walkerlakeprinter's Avatar
Default Help in removing door latch
I am trying to remove the passenger door latch from my 1929 Coupe. I finally had success in removing the four screws with the help of an impact screwdriver. I thought "ah ha!" now it will just come straight out. However, I cannot seem to get it past the lip of the door. Is there a trick to getting it past the door skin seen in the photo? I can't get it angled far enough to get it out.
walkerlakeprinter is offline   Reply With Quote
Old 08-27-2019, 03:19 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Help in removing door latch
Not meaning to ask a foolish question, but are you sure the exterior handle and the inner linkage is removed?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-27-2019, 03:40 PM   #3
walkerlakeprinter
Yes, everything is disconnected.....I got the outside handle off very easily. Nothing else is connected to it. The door latch rod isn't in the way. The whole assembly is loose, it just won't come out.
Old 08-27-2019, 03:49 PM   #4
Jw
pull the latch towards you and push in on the retaining spring and it will come out
Jw is offline   Reply With Quote
Old 08-27-2019, 04:09 PM   #5
walkerlakeprinter
Well, with a bit of prying, I got the latch out. It looks like if I could grind off 1/32" to 1/16" off the side of the latch plate, it would slide right in. I will compare it with the new one when it comes in. Stay tuned.
