02-08-2017, 09:23 PM | #1 |
1940 Ignition Plate Replacement
I am about to remove the bakelite 3-terminal ignition switch plate and the small triangular brush inside for inspection, clean-up, or replacement. Is there anything holding the brush in there and if so, how does the brush detach? Or, will it fall out onto the floorboard when I unscrew and remove the terminal plate? How do you hold the brush up there when reinstalling the plate? Thanks in advance.
02-08-2017, 09:30 PM | #2 | |
Re: 1940 Ignition Plate Replacement
Not to worry.. it only goes together one way.
02-08-2017, 09:39 PM | #3 |
