12-23-2023, 07:26 PM | #1 |
Made my own engine stand adapter.
Made my own engine stand adapter today, as nobody has them in stock.
12-23-2023, 07:53 PM | #2 |
Re: Made my own engine stand adapter.
Well done - it will serve you well and the price is unbeatable!
12-23-2023, 09:01 PM | #3 |
Very nice now sell some!!
www.whidbeymodelaclub.com |
12-24-2023, 04:54 AM | #4 |
Is it pretty well balanced for turning the engine upside down? How far above the oil pan rail is the pivot centerline?
12-24-2023, 07:03 AM | #5 |
May I ask what you do to install the oil pan? Do you remove the lower rail piece??
12-24-2023, 08:27 AM | #6 |
12-24-2023, 08:33 AM | #7 |
12-24-2023, 09:54 AM | #8 |
From experience in doing many of these engines, you are NOT going to like doing it that way. Modern gaskets do not fit that well to begin with, ...and one slipped/pinched gasket generally finds a way to hemorrhaged oil. Might I suggest you consider modifying your design so the pan and the gaskets & seal can be installed with the pan rails facing upward.
12-24-2023, 10:17 AM | #9 |
I added a reduction gear to my engine stand, sure makes turning an out-of-balance item easier.
12-24-2023, 10:30 AM | #10 | |
12-24-2023, 12:46 PM | #11 |
12-25-2023, 04:23 PM | #12 | |
https://www.youtube.com/watch?v=dUJKwFE_NvE |
12-26-2023, 06:46 PM | #13 |
I bought it (new) at a swap meet, it is similar to this:
https://www.alibaba.com/pla/Die-cast...QaAskGEALw_wcB They are available with different ratios, the one I have is 60 to 1
12-27-2023, 09:15 PM | #14 |
I had the oppurnity to see a K.R.Wilson rebuild stand this summer. I came home and nuttered my engine stand. T he support rail must be on top of the oil pan rail. I also offset the mounting point on the water inlet 2 inches to the rear. Engine is rebuilt but no flywheel yet. I will report when complete.
