Old 01-22-2021, 08:41 PM   #1
Washington Blue 36
Default 12 V conversion
12 V conversion. I have a 36 model 68 cabriolet. Wanted to convert it to 12 V. I was able to buy an alternator that looked like a generator for my model A with the 201 and for my 51F1 with the 239. Can’t find anybody who makes an alternator that looks like a generator for the 221 in.³ flat head. Looking for options and suggestions.
Washington Blue 36 is offline   Reply With Quote
Old 01-22-2021, 09:06 PM   #2
Zeke3
Zeke3's Avatar
Default Re: 12 V conversion
Check out ejwhitneyco,com. They do conversion of generators into alternators, 6 or 12 volt.
Zeke3 is offline   Reply With Quote
Old 01-22-2021, 09:15 PM   #3
McMimmcs
McMimmcs's Avatar
if you look in Hemmings there are 4 or 5 techies that will rebuild your casing into an alternator. Not cheap !
McMimmcs is offline   Reply With Quote
Old 01-23-2021, 12:06 PM   #4
Andy
Your 6V gen will charge 12V with no problems. An alternator requires much higher rotation speed which is really not good for the gen mounted fan. More noise and possibility of flying apart. You don’t need an alternator when using 12V.
Andy is offline   Reply With Quote
Old 01-23-2021, 01:37 PM   #5
doghair3
To Washington Blue: If you really want to go down that path check out this guy (Rex). Outstanding quality. He's the man but be prepared to pay. Just remember you only get what you pay for.
https://www.precision-pwr.com/
doghair3 is offline   Reply With Quote
Old 01-23-2021, 06:30 PM   #6
Charlie Stephens
The main problem is that the '36 mounts the fan on the pulley and the front bearing for the alternator is not strong enough for the load. I would go with a later 2 brush generator ('39 standard for one) and have it converted to 12 volts.
Charlie Stephens
Old 01-23-2021, 08:38 PM   #7
GB SISSON
GB SISSON's Avatar
Listen to Charlie... Let's just sat this isn't his first rodeo.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 01-27-2021, 02:39 PM   #8
Washington Blue 36
Thank you for your guidance. My car starts just fine being 6v. really just wanted to hide a 12v car charger. I carry a small portable compressor and wouldn't mind being able to charge a phone. If I converted a spare generator to 12v like you mentioned and since its not putting out the voltage will i have to change anything?
Old 01-27-2021, 08:35 PM   #9
cas3
all the light bulbs, and if going to negative ground, the wires on the amp gauge get reversed, or if its a loop style go thru the loop in the other direction
Old 01-27-2021, 10:05 PM   #10
JSeery
JSeery's Avatar
Missed a few items, change the polarity and resistance for the coil and add a voltage drop(s) for the gauges.
Old 01-27-2021, 10:24 PM   #11
cas3
Smile Re: 12 V conversion
thanks for watching out for me !
Old 01-28-2021, 11:35 AM   #12
marko39
It might be easier to carry a battery pack in your trunk. The one I got my son has 12 volt for jumping, a built in compressor and a 120 vac converter with 3 outlets. It has a light and other stuff I can't remember. Got it at Lowes.
marko39 is offline   Reply With Quote
Old 01-28-2021, 11:56 AM   #13
tubman
tubman's Avatar
There are cheap devices available on Amazon.com that step up 6 volts to 12 volts. As long as you can isolate the output (no common ground), one of these will easily run a cell phone charger or similar device with no problem. My partner and I designed and built a 6 to 12 volt converter with a common ground. I have it installed in my '51 and use it to run a GPS, a backup camera, a CD player, and it also has an extra 12 volt power outlet. It works fine, but since most anything you want to run can be electrically isolated, there was no market for such a device at the price it would demand.
You can become dependent on backup cameras, however.
Old 01-28-2021, 11:57 AM   #14
TJ
TJ's Avatar
I think Marko's idea is the best.
Old 01-28-2021, 12:50 PM   #15
corvette8n
corvette8n's Avatar
Don’t buy the 3 in 1 jump pack from Walmart, Everstart brand mine only lasted a year, then the electronics went bad.
Old 01-28-2021, 01:53 PM   #16
TJ
TJ's Avatar
Do a search at Amazon as suggested by tubman.. There are several 6 volt to 12 volt converters there for less than $20. They will allow you to charge your phone or run a modern radio. Don't know if the will run a compressor or not.
Thread Tools
Display Modes
