Old 01-22-2021, 08:46 AM   #1
Ed in Maine
Default Replacing Rear Drum Seal
I am in the process of installing new emergency brake lining and while things are apart I would like to change the grease seal in the rear drums. What is the easiest way to pull the old seal out? Thank you, Ed
Ed in Maine is offline   Reply With Quote
Old 01-22-2021, 11:02 AM   #2
Will N
Will N's Avatar
Default Re: Replacing Rear Drum Seal
There's an inexpensive tool called a seal puller that works best.
Will N is offline   Reply With Quote
Old 01-22-2021, 12:10 PM   #3
Jim Brierley
I just use a tire iron or large screwdriver.
Jim Brierley is offline   Reply With Quote
Old 01-22-2021, 02:22 PM   #4
McMimmcs
McMimmcs's Avatar
Harbour Freight has automotive wheel seal puller for-less than $15 dollars.
McMimmcs is offline   Reply With Quote
Old 01-22-2021, 02:48 PM   #5
Mel Gross
We pull a lot of seals out of rear brake drums when we do brake jobs. The best and easiest way to pull / pry a seal is to use a tire iron or crowbar and put a block of metal or even a block of wood that is a little taller then the seal in the center of the bearing and use it instead of the edge of the hub. You can damage the edge of the hub. Seals are an one time part and will not come out intact. You might have to tap the tire iron or crowbar into the seal to get a good grip.
Mel Gross is offline   Reply With Quote
Old 01-22-2021, 02:53 PM   #6
Tom Endy
Tom Endy's Avatar
This photo was posted on fordbarn a number of years ago. The tool was made from the tapered end of a discarded Model A axle or drive shaft. The tool is inserted into the taper of the drum and used as a platform to assist the crow bar to pull the seal out.
Tom Endy
Tom Endy is online now   Reply With Quote
Old 01-22-2021, 03:30 PM   #7
Synchro909
Synchro909's Avatar
Tom Endy
So simple, it is genius.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 01-22-2021, 05:57 PM   #8
Conaway2
Conaway2's Avatar
I use a big screwdriver to remove the seal. Brattons and other suppliers sell a tool to install the new seal to exactly the correct depth.
Jim
Conaway2 is offline   Reply With Quote
Old 01-22-2021, 07:45 PM   #9
1crosscut
1crosscut's Avatar
After pulling the lock ring drop the drum assembly from a couple feet above the floor onto a piece of cardboard and the momentum of the bearing will push the seal out. May take several drops and even a bit of a push when dropping to get them out.
Hardest part is getting the lock ring out. Use a small screw driver to pry one end of the lock ring out a bit and at the same time place an awl in behind the lock ring to keep it out and work your way around.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 01-22-2021, 07:53 PM   #10
McMimmcs
McMimmcs's Avatar
Tricks of the trade my friend, tricks of the trade! Not sophisticated but very workable and time tested! Wayne
Old 01-22-2021, 08:27 PM   #11
Ranchero50
Yeah, getting them in to the correct depth was more difficult than the removal.
Building a '29 Speedster, the hard way...
Ranchero50 is offline   Reply With Quote
Old 01-23-2021, 10:08 AM   #12
Ed in Maine
Thank you for all your comments, Ed
Old 01-23-2021, 01:39 PM   #13
Jim Brierley
If the seal has worn a grove in the axle housing it can be spaced out a bit to find a better spot for it.
Old 01-23-2021, 04:17 PM   #14
Synchro909
Synchro909's Avatar
I do that on just about every rear end I have done. (usually 2-3 mm is enough)
