Old 01-19-2021, 01:34 PM   #1
ford35lh
Default Changing color of frame
I bought a restored 1 1/2T chassis ,complete except for the engine.
The color is silver gray and I want to paint it black.
It appears that the metal was blasted as the pitting is not too deep and very clean.
I tried rubbing a remote area of the paint with laquer thinner,brake fluid and carb cleaner.
It was untouched.
Any suggestions how to overcoat this paint ???
ford35lh is offline   Reply With Quote
Old 01-19-2021, 02:59 PM   #2
Krylon32
Default Re: Changing color of frame
Sounds like your frame may have been powder coated by the resistance you are finding trying to remove the finish. If you determine this, I have scuffed the surface with a DA with 120 grit and repainted it with enamel which held up very well.
Krylon32 is offline   Reply With Quote
Old 01-20-2021, 01:40 AM   #3
ford35lh
To clarify: all chassis and running gear parts have been painted individually,
before assembly.
Old 01-20-2021, 12:33 PM   #4
J Franklin
J Franklin's Avatar
Just paint it as Krylon32 recommends if you wan't it a different color. You nor the factory needs or did paint things separately.
Old 01-20-2021, 12:44 PM   #5
19Fordy
19Fordy's Avatar
Use a high quality etching primer and then then paint it.
Call Eastwood and see what they sell.
Old 01-20-2021, 01:13 PM   #6
J Franklin
J Franklin's Avatar
Primer is usually for use on bare metal. If the base paint is in good condition I clean and scuff only before top coat. the less build the more solid the job.
Old 01-20-2021, 01:15 PM   #7
Fortunateson
Could the coating be Imron? I heard that stuff is really hard.
Fortunateson is offline   Reply With Quote
Old 01-20-2021, 01:32 PM   #8
1952henry
1952henry's Avatar
Or could be PoR 15, maybe KBS Rust Seal. I have used the Rust Seal on sandblasted transmission parts. Once cured, it is hard. Sand paper just scuffs it enough for their top coat.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 01-20-2021, 11:00 PM   #9
Brian
Brian's Avatar
Or...re-sandblast the frame; no need to remove the coating that's on there, but sandblasting will provide a good 'tooth' for your desired paint system to adhere to.
Unfortunately, two half wits don't make a whole wit!
Brian is online now   Reply With Quote
Old 01-22-2021, 08:15 AM   #10
Frank Miller
Frank Miller's Avatar
Here is an approach. First determine what you would like to pain it with. Take a small part off the chassis and scuff it with sandpaper and paint it. If it looks ok and appears to have stuck you should be ok. I have doubts about a truck frame that big being powder coated but I could be wrong.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 01-22-2021, 10:15 PM   #11
1952henry
1952henry's Avatar
[QUOTE=Frank Miller;1976711]Here is an approach. First determine what you would like to pain it with. Take a small part off the chassis and scuff it with sandpaper and paint it. If it looks ok and appears to have stuck you should be ok. I have doubts about a truck frame that big being powder coated but I could be wrong.[/QUOT
That is a sound idea.
