01-12-2021, 01:14 PM | #1 |
Steering Free Play Update
I have looked at the tie rod and drag link and see that the end caps in some cases are not flush with the rod. Some appear to be in too far. The Model A Service and Maintenance Guide recommends that the end caps be screwed in to compress the springs 25%. How do you verify that? After the end cap contacts the ball cap does anyone know how many turns the end cap has to go to compress the spring 25%? Thanks for your help. Ed
01-12-2021, 01:30 PM | #2 | |
Re: Steering Free Play Update
01-12-2021, 01:35 PM | #3 |
01-12-2021, 01:49 PM | #4 |
Take out the spring and measure its length. Count the threads per inch of the threaded plug. (1/4) X (Spring Length) X (Threads per Inch) = Number of Turns
I don't know the actual number but let's say the spring is 3/4" long and the thread is 32 threads per inch. 1/4 X 3/4" X 32 = 6 turns from the time that the threaded plug touches the spring. Like I said, I don't know the actual measurements. I could not find them online. |
01-12-2021, 01:49 PM | #5 |
Thank you for the input. I am working on the drag link, the end over the front axle. I just put the end cap flush with the drag link by a 1/4 turn after contacting the ball cap. In other words, there is very little compression on the spring. How many turns further in with just this light load? Ed
01-12-2021, 01:52 PM | #6 |
01-12-2021, 02:02 PM | #7 |
How tight?
German method: Gudentight Russian method: Stripinthenutsoff Polish method: Knuckleowski No political correctness here. |
01-12-2021, 02:15 PM | #8 |
GeneBob, that is what I did yesterday. I took it out for a test drive and after I made a turn, I had to pull the steering wheel back to the forward position. I didn't realize that those little cups can create a lot of drag if they are too tight. Today I am trying to correct the mistakes I made yesterday. It is a good thing I am retired to have the time to mess around with botched repairs like this! Ed
01-12-2021, 02:16 PM | #9 |
PM sent.
Marshall |
01-12-2021, 02:40 PM | #10 |
Marshall, thank you for your input. Ed
01-12-2021, 03:10 PM | #11 |
If you tighten the springs on the tie-rods then the toe should definitely be reset.
Thread Tools | |
Display Modes | |
