Old 01-05-2021, 01:50 PM   #1
vern hodgson
Default Horn, for what?
Cleaning horn armature and brushes, these appeared on the table, must have to do with the brushes. Where and how do they fit in and are they necessary?
vern hodgson is offline   Reply With Quote
Old 01-05-2021, 01:58 PM   #2
GRutter
GRutter's Avatar
Default Re: Horn, for what?
Vern -
A picture would be helpful
GRutter is offline   Reply With Quote
Old 01-05-2021, 02:39 PM   #3
Patrick L.
Patrick L.'s Avatar
Whatever they are, they're probably necessary. [smiley face]
Old 01-05-2021, 04:49 PM   #4
Synchro909
Synchro909's Avatar
I saw nothing that had been left out so I don't think it will matter if it is put back together without them.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 01-05-2021, 06:00 PM   #5
J Franklin
J Franklin's Avatar
Talking Re: Horn, for what?
Know what we mean Vern?
Old 01-05-2021, 07:23 PM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Does this help?
File Type: jpg 49D4FBC6-FC93-4070-986E-3A6AB726F6E5.jpg (10.0 KB, 101 views)
Old 01-05-2021, 08:42 PM   #7
vern hodgson
Oh, guess I forgot to post photo! Duh!
File Type: jpg 23E3070B-442B-4A85-BBF6-85CF59AE0A5E.jpg (19.4 KB, 221 views)
Old 01-05-2021, 10:42 PM   #8
GRutter
GRutter's Avatar
Picture isn't clear enough to determine what those are, or what they are made of.
At first glance I thought they might be the horn terminal connectors, but those should be soldered to the ends of the field coils.
Old 01-06-2021, 09:26 AM   #9
Badpuppy
http://modelabasics.com/
Just about everything you need to know about everything.
Badpuppy is offline   Reply With Quote
Old 01-06-2021, 12:48 PM   #10
vern hodgson
Brass angles, bent at bout a 45 degree angle, each leg about 3/16” by 3/16” wide.
Old 01-06-2021, 06:15 PM   #11
rotorwrench
rotorwrench's Avatar
The brush holders are made of brass. Look the terminals and the brush holders over and make sure they are intact.
Old 01-06-2021, 06:45 PM   #12
rickranger
How many times did you have to hear "Hey Vern..." in the 80's?
rickranger is offline   Reply With Quote
Old 01-07-2021, 02:29 AM   #13
vern hodgson
A lot, know what I mean?
Old 01-08-2021, 04:49 PM   #14
JayJay
Some of the brass brush holders have gizmos in them to hold the brush against the brass in the long dimension so they maintain good contact with the brush holder and don't float around. Not the springs on the end, but they push sideways against the brush when you insert the brushes into the holder. I can't tell from the photo but is it possible that's what you have? You would be able to fit them inside the brush holder if so.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
JayJay is offline   Reply With Quote
Old 01-08-2021, 06:06 PM   #15
ericr
ericr's Avatar
Vern do you know what make of horn it is?
ericr is offline   Reply With Quote
