Old 12-28-2020, 12:59 PM   #1
Y-Blockhead
Y-Blockhead's Avatar
Default Tillotson Round Bowl Carb.
While perusing e-Bay I saw the Tillotson 'Round Bowl' carburetor and I thought it was a copy of a Zenith. And it got me curious. Are these carbs pot metal like the 'Square Bowl' Tillotsons or are they cast iron like Zeniths. Hard to tell from pictures since someone bead blasted the carburetor (I hate when they do that). Also looks like it may have an accelerator pump?
Not looking to buy, just looking for info to fill some of my remaining KB of memory...
Old 12-28-2020, 01:22 PM   #2
abachman3
abachman3's Avatar
Default Re: Tillotson Round Bowl Carb.
It is pot metal, like the other Tillotsons.
abachman3 is offline   Reply With Quote
Old 12-28-2020, 02:01 PM   #3
P.S.
I have one of them. It is pot metal, but not very good quality. It does not have an accelerator pump on it. I don't know what that extra adjustment does since I have never ran it on a car. It's just on the display shelf as an oddity. Drop by and examine in person if you wish.
P.S. is offline   Reply With Quote
Old 12-28-2020, 03:53 PM   #4
Ed in Maine
I have worked on both and the Zenith is a much better made carburetor. I find that the threaded holes in the pot metal can be very iffy! You can go through all the work of rebuilding only find that the threads in the body are weak. Ed
Ed in Maine is offline   Reply With Quote
Old 12-28-2020, 05:21 PM   #5
Flathead
Flathead's Avatar
If you have a good core to rebuild, the F-1B is a decent carb. Gaskets are available from Smith and Jones Model A Parts. The float and float valve are the same as Zenith. They are held together with a single bolt like the Zenith, be sure the upper and lower castings fit tight without a gasket before assembling, and be sure all passages are clean. There is an older issue of Skinned Knuckles magazine that has a good article on this carb. with a schematic of the internal passages. There are a lot of these out there so they must have sold quite a few "back in the day".
Flathead is offline   Reply With Quote
Old 12-28-2020, 06:07 PM   #6
Y-Blockhead
Sorry, I forgot to add picture. The area in the red circle is what I was referring to about the accelerator pump? Or a power valve maybe??
Old 12-28-2020, 06:28 PM   #7
rogerkb1936
rogerkb1936's Avatar
it is an enrichening valve for high power settings. i ran one of these years ago and it was ok. had another that crumbled in my hand
rogerkb1936 is offline   Reply With Quote
