Old 12-07-2020, 10:36 PM   #1
tommyleea
Default 23T engine removal
All disconnected to remove the engine for magneto ring R&R. Question about the radius rod connection at the crankcase. I have it disconnected, but it is still "there". Seems like it will still interfere with the engine removal. Will it flex enough to clear once I start removing the engine? Also, one of the steps is to remove the hood shelves. What purpose does this serve? Thanks
tommyleea is offline   Reply With Quote
Old 12-07-2020, 10:40 PM   #2
29spcoupe
29spcoupe's Avatar
Default Re: 23T engine removal
You may have to force the wishbone down to slide the engine forward. You need to remove the hood shelves to slide the engine forward when you slide the engine forward under the firewall.
29spcoupe is offline   Reply With Quote
Old 12-08-2020, 12:57 PM   #3
tommyleea
OK..Thanks..
Old 12-10-2020, 10:56 AM   #4
tommyleea
The board idea worked well, engine is out and on the stand. Thanks
Old 12-11-2020, 01:49 AM   #5
redmodelt
redmodelt's Avatar
I back off the perch nuts and let it hang down. Will make it easier to reinstall the engine too.
Old 12-11-2020, 10:51 AM   #6
tommyleea
I might try that for install. Seems would make it easier. Thanks
