11-11-2020, 09:43 AM | #1 |
Model T in Roundabout
Haven't gone there yet. 23 T Roadster. There are a couple of roundabouts on the way to town. Can you slow down enough in high gear to navigate the roundabout (15 mph), or should you downshift to low? Thanks
11-11-2020, 10:23 AM | #2 |
Re: Model T in Roundabout
Guess a lot would depend on your engine, but I would stay in high maybe retard the spark then advance it when you came out. Just go try. Not sure why you would worry about going thru a roundabout your just slowing down some. Even back when I was learning to drive a T, I wouldn't have given it a second thought.
11-11-2020, 10:38 AM | #3 | |
11-11-2020, 12:21 PM | #4 |
Sure it can stall, but low is just used to get the car rolling. At 15 MPH you would have the RPMs up pretty high in low. Besides you shouldn't shift in to low at at speed anyway, the shift into low would be about the same as low to high range.
11-18-2020, 08:32 AM | #5 |
If mixing with traffic is your issue, claim your SENIORITY, be sure to have a good working horn, and USE it. Use it for attention, use it like toy. Wake them up to your presence. They often need a double take to penetrate their airconditioned,, music and media,, device laden,, experience! If pulling in high at a low. slow speed ( Level Ground as a Roundabout ) is difficult, get with an experienced tuner to find the answer. The power should be there.
Enjoy yer day. Tom Hate can't fix what it started. |
