08-18-2020, 02:14 PM | #1 |
temperature senders
I have a temp. sender that reads hot all the time. Is there any way they will come apart?. I;m trying to save 55.00. dollars. thanks for any info. Jack .
08-18-2020, 03:31 PM | #2 |
Re: temperature senders
Which sender are you trying to repair? The single terminal one is the actual Temperature sender and the one with two terminals is just a switch that goes open between the two terminals when it gets 'too' hot. You can check the operation of the single terminal sender by shorting the terminals of the two terminal unit together. This will help you determine which unit is actually faulty.
I have heard of a guy who removes the crimped top part on a lathe to get access to the internals and then solders them back together once repairing and cleaning the contacts is completed.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
08-18-2020, 04:18 PM | #3 |
I have done this and it worked. Check out post #5 and on on this thread. As I say in the thread, I was just fooling around and wasn't too careful with my work, so it doesn't look the best. If you are a bit more careful, you should be able to a better job.
https://www.fordbarn.com/forum/showt...ht=temperature |
08-19-2020, 07:04 AM | #4 |
Thanks for the reply guys the sender is on the drivers side. With it on hooked the heat gauge reads normal . Jack.
08-19-2020, 11:20 AM | #5 |
Thread Tools | |
Display Modes | |
