Old 11-07-2018, 09:14 PM   #1
duke36
Default Brumfield BF head and timing
What settings suggested for Brumfield BF heads?
1. point gap
2. timing (BTDC, etc)
duke36 is offline   Reply With Quote
Old 11-07-2018, 09:42 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Brumfield BF head and timing
Set it by the book but you might have to retard the spark more to stop pings on hills. I like my Brumfield head! my 3x plugs are gapped .028 and it runs great!
Old 11-08-2018, 05:52 AM   #3
Bruce of MN
Bruce of MN's Avatar
Stock ignition?
Bruce of MN is offline   Reply With Quote
Old 11-08-2018, 08:00 AM   #4
kenparker
kenparker's Avatar
I have run Brumfield heads for 25 years. My points are set at .018 to .020 and the spark plug gap is set to .030. Distributor has the Nurex upper plate with "modern" mustang style points. Oh, one mo thang 3X plugs.
kenparker is offline   Reply With Quote
Old 11-08-2018, 04:55 PM   #5
J Franklin
J Franklin's Avatar
Originally Posted by Bruce of MN View Post
Stock ignition?
I run a B distributor set to specs.
Old 11-08-2018, 06:59 PM   #6
Charlie Stephens
Try asking your question at AHOOGA.COM. Larry Brumfield spends a lot of time there and you should get an answer from him directly.
Charlie Stephens
Old 11-08-2018, 07:52 PM   #7
duke36
Stock ignition?
stock distrib. with Champ W18 plugs.
Old 10-24-2021, 10:10 AM   #8
Big hammer
Stock point gap, stock base timing, just don't advance the timing with the hand lever as much like stock. You could make a stop to keep from hand lever advancing to much timing. Or just listen to the engine if it starts knocking retard the timing with the hand lever. Go for a drive and find out what your car wants, enjoy the drive!
get a bigger hammer tap done
