10-18-2014, 06:50 AM | #1 |
B water pump heads
In the "Head molds" thread one person expressed a need for an iron head with a B pump end with 6:1 compression. Anyone else interested in B style? I would like to see at least 30 people interested before I start cutting the pattern. The top is already modeled up and I have a 6:1 chamber. I would need to model the core plug and then make them.
$400.00 Email me. Tod |
10-18-2014, 09:21 AM | #2 |
Re: B water pump heads
Why 6:1 ? You (Snyder's) already have an 6:1 A head that can be used on a B.
The B engine has larger bearings, semi-pressure oil and an auto advance dizzy. The street CR sweet spot for later 40's-60's flatheads is in the 7-8 range. Something like a 7.6:1 with a Ricardo style chamber and clearance for 1.75 intakes with .400 valve lift would fill a now vacant niche for the B's. Chambers would need to be ~ 120cc. Looking backward, It could also be used on an A with the B pump, leaving a more 'stock Ford' look than some of the higher CR aftermarket A heads. |
10-18-2014, 01:30 PM | #3 |
Will your head pass for original on a restored Model B? You might also want to place this in the Early V8 section that covers 1932.
Charlie Stephens |
10-18-2014, 05:24 PM | #4 | |
Tod |
10-18-2014, 05:25 PM | #5 |
10-18-2014, 06:26 PM | #6 |
almost all the performance heads in the past were A model water pump design including accessories such as Cragar water pumps and V8 to A model pumps ect A Model water pumps are easier to find and much lower cost just check the cost difference and many of the parts houses do not carry B pumps Colin |
10-18-2014, 10:58 PM | #7 |
I want one .
10-19-2014, 01:47 AM | #8 | |
This is exactly what my thoughts were. I just have a hard time thinking that 30 B guys are going to step up to buy. This, of course , would be more for stock restorer guys..but with more c/r built into head. B pumps are , for some reason, scarcer and more costly than any A pump I've seen. For Tod, it is all about if it is feasible ..$/investment wise. I hope 30 guys step up. Maybe someone familiar with HAMB can give that forum a heads up also ? |
10-19-2014, 02:18 AM | #9 |
I for myself really want Tod to be successful because I want to buy good quality new performance heads at a good price
I do not want Tod making heads that are slow to sell and having money tied up for years how many must be sold to break even ?? That may mean losing him to another section of the market I know this just me being very selfish Colin |
10-19-2014, 09:18 AM | #10 |
I don't have a model B but I can see where some that do and want to keep the original look would be glad to get the extra power of a 6;1 head. Another thing, If a person has a model B they will more than likely already have the three bolt model B pump. If a person really needs one, new B pumps are available.
10-19-2014, 12:07 PM | #11 |
When I said I'd like to see 30 commitments to get things going I was padding things a little, to be honest. I had originally typed '25' but upped it to 30. If I can get even 20, I think I can make it work. Looks like 2 so far, so, if we get to 20 I'll do it.
Tod |
10-19-2014, 12:11 PM | #12 |
Possibly post on the HAMB also to see if any extra interest there. I will ask a friend locally to see if he is interested in one also. I think it is a great idea. If I still had my B engine I would be in for one. Rod
10-19-2014, 12:48 PM | #13 |
Actually the Model B water pump is a big improvement and doesn't over pump as badly as the model A pump. Another advantage is the B pump and fan can usually be removed without moving the radiator. The water neck is part of the pump so the problem of breaking water necks is no longer an issue. For speedsters and hot rods The B style head and pump would be the better way to go, especially if a variety of combustion chamber choices are possible. Just my thoughts.
10-19-2014, 02:28 PM | #14 | |
Tod |
10-19-2014, 06:47 PM | #15 |
I know you have parts are almost done but, have you looked a the head off a Briggs & Stratton? Different shape and they seem to make more hp/cu-in than a Model A.
10-19-2014, 06:59 PM | #16 |
Tod,
Are the heads going to be cast iron or aluminum? Charlie Stephens |
10-19-2014, 07:53 PM | #17 |
10-20-2014, 06:13 AM | #18 |
10-20-2014, 10:12 AM | #19 |
Originally Posted by Charlie Stephens View Post Tod, Are the heads going to be cast iron or aluminum? Charlie Stephens ************************************************** ****************** Yes. Tod ************************************************** ****************** Tod, Yes, what? I probably should have asked, "What are the heads going to be made of?" Charlie Stephens Last edited by Charlie Stephens; 10-20-2014 at 10:21 AM. |
10-20-2014, 10:15 AM | #20 |
Come on Charlie, he answered "yes" to both.
