08-06-2013, 08:01 PM | #1 |
21A-12127 and 59A12-12127...?
Dear Friends!!!
I ´d like if someone can explain me, which is the difference between both distributors? My engine is a Ford 1946 59AB, Which is the correct one? Thank for your helps. Hary.
I love my Ford V8 1946! Harylufa! |
08-07-2013, 06:32 AM | #2 |
Re: 21A-12127 and 59A12-12127...?
21A-12127 is the 42-44, 8 cyl. distributor with the flat one piece cap(crab), the distributor has clips to hold the cap in place.
59A- is the 45-48, 8 cyl. distributor with the larger two piece cap, the distributor body has a bail to hold the cap in place. see page 506 of the green parts book. There are no major changes in the two distributor body except for the cap mounting. They can be interchanged. Aftermarket suppliers have the mounting clips to change the bail out and replace the two piece cap with the "crab" style one piece. Last edited by Terry,OH; 08-07-2013 at 06:39 AM. |
08-07-2013, 06:36 AM | #3 |
In other words, there the same dist, just change the caps. Walt
08-07-2013, 09:24 AM | #4 | ||
Ah ok, it is just change the caps. My engine is installed with distributor two piece cap that has bail to hold the cap. I wonder if not being the original one could have some problem with timing. Terry, which is that book you mention? I have a book that says "Ford V8 service bulletin 1941-1948 complete" Must I get another book with info? Thanks for posting
08-07-2013, 09:30 AM | #5 |
Don't forget each dist cap style requires its own unique size rotor.
08-07-2013, 09:39 AM | #6 | |
You are right, I noticed there are different rotor. Thanks Hary
08-07-2013, 10:18 AM | #7 |
It is commonly referred to on this forum as the "Green Bible". It is the Ford Chassis Parts and Accessories Catalogue for 1928-1948. Here are some for sale on ebay: http://www.ebay.com/sch/i.html?_odkw...logue&_sacat=0
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
08-07-2013, 12:50 PM | #8 |
A little warning here on the crab units.
The rabbitt ear crab distributor also comes in a couple different configurations. Both cast iron and aluminum. If you look at this pic from our wall the outter ring for the two piece distributor cap is thicker and this one has a vent at the bottom . A standard cap wont fit this distributor. Also notice that the locating pin for the distributor cap is internal only using a pin in the housing. This example dont have the side tangs but some do as well This one is aluminum but we have both in the box cast iron and aluminum...The internal parts are the same . Also the cast unit uses a brass sleeve for the vacuum brake..... |
08-07-2013, 07:35 PM | #9 | |
I have not this book, I must buy it. I see this book is in CD too. Thank for this info. Harylufa.
08-07-2013, 07:52 PM | #10 | |
Thank for your explanation. So, a 21A-12127 can perfectly suit in my engine too, am I right? Now, after checked my dist installed now is a 59A-12127. This dist is not thicker and has not a vent at the bottom. I really appreciate these kinds of help. Hary
