Old 01-22-2021, 09:00 AM   #1
rockfla
rockfla's Avatar
Default Advice on restoring hub caps
Anyone restored Mercury/Ford caps of this type?? I heard about drilling the hole in back side of shell and using compressed air to "pop" the SS cap off the shell. SO my questions are:
1) What size hole did you drill?? I would imagine around an 1/8, 3/16th maybe???
2) The biggest question of them all, what method did you use to get the caps back on the shell???
Thanks
Rockfla
Old 01-22-2021, 09:16 AM   #2
big job
big job's Avatar
Default Re: Advice on restoring hub caps
I'm confused as usual.?. Why not just buff the stainless and paint the surround ? Then
use a paint pin for lettering. And second I would not use a twist drill. If you must separate the parts buy a end mill used on milling machines, it will make a flat hole not a V hole..thats what I would do......sam
big job is offline   Reply With Quote
Old 01-22-2021, 09:28 AM   #3
rockfla
rockfla's Avatar
What is "pictured" is just for "reference" purposes "only".......I have a set of caps that are "dented" "Scuffed" and "Scratched" and ALL need to be "worked"!!!!
Old 01-22-2021, 09:30 AM   #4
Zeke3
Zeke3's Avatar
Rockfla, here is the link to a step-by-step procedure to restore these hubcaps. Hope this helps out.
https://www.fordbarn.com/forum/showt...ghlight=hubcap
Zeke3 is offline   Reply With Quote
Old 01-22-2021, 09:38 AM   #5
rockfla
rockfla's Avatar
Thank you very much Zeke3, funny how the mind works OR in this case didn't work as I never thought to do a "Search".....Thanks for making me feel stupid!! LOL.
IF any interest, I will document my project and post pictures AGAIN if any interest!!!
Old 01-22-2021, 10:19 AM   #6
nelsb01
nelsb01's Avatar
If you read the link to the hubcap repair, here is a picture of the form I made. Please note that the hubcap was 1936 and not your 1939 cap.
nelsb01 is offline   Reply With Quote
Old 01-22-2021, 10:26 AM   #7
Zeke3
Zeke3's Avatar
Thanks Bruce for sharing the information on your techniques for disassembling and reassembling these caps. It is a project I plan to tackle in the future.
Old 01-22-2021, 10:40 AM   #8
rockfla
rockfla's Avatar
YES, thank you as a picture is worth a 1000 words!!!
Old 01-22-2021, 02:21 PM   #9
hotcoupe
hotcoupe's Avatar
Hello, i have restored several of that type of hubcap, to remove the S.S. skin (approx. 0.012" thick) i use a #60 drill bit and just pierce the carbon steel cap, apply high pressure air and the outer skin usually pops off. To re-install the outer cap, place the carbon steel cap in the freezer overnight and heat the S.S. cap to 250*, and the outer cap will slide right on.
Tom
hotcoupe is offline   Reply With Quote
Old 01-22-2021, 02:25 PM   #10
hotcoupe
hotcoupe's Avatar
Tried to post images, no luck.
Tom
Old 01-22-2021, 02:36 PM   #11
rockfla
rockfla's Avatar
Tom
Wow, thanks Tom, will give that a try!!!!
Old 01-22-2021, 02:37 PM   #12
hotcoupe
hotcoupe's Avatar
Images, maybe.
Old 01-23-2021, 02:36 PM   #13
Gregger Rod & Custom
Gregger Rod & Custom's Avatar
That is fantastic information.
Thanks for posting the link,
Greegger
When you turn on your car, does it return the favour?
Gregger Rod & Custom is offline   Reply With Quote
Old 01-23-2021, 06:40 PM   #14
JSeery
JSeery's Avatar
Added for hotcoupe
Old 01-23-2021, 07:03 PM   #15
Woodie1
Woodie1's Avatar
I tried the air method blowing through a small hole & had 1 pop off out 5 I tried.
Woodie1 is offline   Reply With Quote
Old 01-24-2021, 12:21 AM   #16
mercman from oz
mercman from oz's Avatar
Those 1939 Ford Mercury are very rare hubcaps.
Old 01-25-2021, 07:59 AM   #17
rockfla
rockfla's Avatar
Trevor, I just scored another set of 4 that need "restoration", thus the reason for the post.
Old 01-25-2021, 07:59 AM   #18
rockfla
rockfla's Avatar
SO, how did you remove the other 4 If you don't mind me asking or sharing???
Old 01-25-2021, 09:05 AM   #19
nelsb01
nelsb01's Avatar
Make sure that your blower attachment has the rubber tip. That makes sure you seal the drilled hole and get the direct pressure of the air.
And you shouldnt need a lot of air pressure -- usually 20 lbs works.
