Old 12-31-2020, 07:54 PM   #41
WHN
Default Re: Troubleshooting advice
Spark, valves, or gas!
Don’t start taking things apart. Try the MMO. Has helped solve a lot of engine problems with stored engines.
Enjoy.
Old 01-01-2021, 08:31 AM   #42
barrelnose
When there is clearance in #4 valves, what is the clearance?
Is there any?
barrelnose is offline   Reply With Quote
Old 01-02-2021, 12:31 PM   #43
Dewshan
Is there any?
no clearance on #4 at TDC hope that is correct!
Dewshan is offline   Reply With Quote
Old 01-02-2021, 12:33 PM   #44
Dewshan
I think I have a fuel flow problem....fuel was just a small trickle. gas tank still has some junk in it and is plugging up the shut off valve. Going to flush it out better and get some more of the rust out. then get one of the filters that sticks up from the shut off valve into the tank.
Old 01-02-2021, 08:16 PM   #45
1crosscut
1crosscut's Avatar
Probably be a good time to open up the carb for a look see while you are waiting on the pencil filter to arrive.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
