10-29-2020, 04:14 PM | #1 |
Best practice in removing '54 F100 doors
I am restoring a '54 F100. Looked at door hinges and access to the pillar 6 bolts or the access door on the door itself (6 bolts). It seems that the door bolts make an easier removal. Any advice out there? Thanks.
10-29-2020, 04:19 PM | #2 |
Re: Best practice in removing '54 F100 doors
Did the door bolts on my project. Makes it so much easier to reinstall too.
10-29-2020, 07:26 PM | #3 |
If the doors fit good now, take some pics of the bolt locations on the door for easier reassembly.
10-29-2020, 07:55 PM | #4 |
If you drill an 1/8th inch hole thru the door side of each hinge into the door before disassembly, you can use them to index the door into the original position when reassembling.
10-30-2020, 02:57 PM | #5 |
