Old 02-27-2021, 01:16 PM   #1
rfitzpatrick
Default Tire Stems
Why are the stems so tall? Having trouble servicing without bending them over, which I don't think should be done.
Thanks
rfitzpatrick is offline   Reply With Quote
Old 02-27-2021, 01:34 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Tire Stems
Yes, they are tall. I have one 90 degree air nozzle that snaps onto my air hose that fits over the stem without tweaking the stem. Never good to bend the stem while airing up tires.
Mike Peters is offline   Reply With Quote
Old 02-27-2021, 07:50 PM   #3
Gary Karr
Gary Karr's Avatar
You should not have a problem with the length of original Model A stems other than the Schrader 888's that use a 3" dust cover. What stems are you running?
Gary Karr is offline   Reply With Quote
Old 02-27-2021, 09:21 PM   #4
McMimmcs
McMimmcs's Avatar
Harbor Freight sells a kit that contains numerous air hose ends. One is perfect for the Model A. About $12 dollars.[
McMimmcs is offline   Reply With Quote
Old 02-28-2021, 07:33 AM   #5
Chris in WNC
Chris in WNC's Avatar
On a recent road trip, I learned that most air dispensers out on the highway have a long nozzle that is incompatible with metal valve stems.
Will be carrying my 90 degree nozzle on the next trip.....
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 02-28-2021, 10:50 AM   #6
rfitzpatrick
What ever stems that came with the tubes -- I was just wondering why do they have to be so tall. At my age, I've trouble bending my back, and now?
I'm looking for 'easy'
Old 02-28-2021, 12:01 PM   #7
Ruth
Thanks
That's a good question that I have asked myself every time I check my tires. Mine are the rubber stems. Are the metal stems shorter.
Which brings up another question; Has anyone ever used a motorcycle tube in a model A tire? Is it even feasible? I see Coker has a tube with a 1½" tall stem.
Ruth
