Old 02-16-2021, 10:03 AM   #1
packrat6
Default gas gauge float replacement
is it possible to replace the cork float without removing the whole gauge....ie, bending wire arm enough to get float off and putting new cork on then "unbending" the wire arm?
packrat6 is offline   Reply With Quote
Old 02-16-2021, 10:19 AM   #2
JKY
Default Re: gas gauge float replacement
Anything is possible, but in this case, it's not really practical.
JKY is offline   Reply With Quote
Old 02-16-2021, 10:44 AM   #3
Will N
Will N's Avatar
Good chance of breaking the wire by working it back and forth like that.
Will N is offline   Reply With Quote
Old 02-16-2021, 10:59 AM   #4
redmodelt
redmodelt's Avatar
Also you would end up breaking the old cork to get it off with the pieces now in the tank and there is a washer and upset on the end of the rod, it does not just slide on. There wouldn't be a way to lock the new one in place.
Old 02-16-2021, 11:36 AM   #5
katy
katy's Avatar
Kind of like "building a ship in a bottle".
Old 02-16-2021, 11:41 AM   #6
packrat6
i'm convinced. tanx
Old 02-16-2021, 12:02 PM   #7
JayJay
It's not a huge deal to pull the entire gas gauge assembly - you can do it without removing the instrument panel, but it's easier if you do. I'd suggest that you get a "gas gauge rebuild kit" and a set of the special wrenches from the vendors. Be sure to get the fuel level in your tank well down before you do. Most of the Model A maintenance or restoration books have the procedure, but if you're at all mechanically inclined it's pretty intuitive.
Most gauges that have been in for a while have hardened gaskets anyhow and leak vapor a bit so it's good to refresh the gaskets.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
JayJay is offline   Reply With Quote
Old 02-16-2021, 01:54 PM   #8
George, Iowa
George, Iowa's Avatar
Packrat, most Model A clubs have a loaner gas gauge tool if you want to go that route. Where are you located?
Some is not a number...
Soon is not a time...
and hope is not a plan.
George, Iowa is offline   Reply With Quote
Old 02-16-2021, 02:48 PM   #9
1931 flamingo
1931 flamingo's Avatar
DISCONNECT the BATTERY first. Use CORK gaskets.
Paul in CT
Old 02-17-2021, 03:42 AM   #10
john charlton
john charlton's Avatar
Use the flat steel laser cut nut removal tool . The pot metal version normally slips off, no doubt made offshore by someone who has no idea of its purpose .
John in Suffolk County England ,weather was cancelled today .
john charlton is offline   Reply With Quote
Old 02-17-2021, 02:46 PM   #11
packrat6
Thanks to all for feedback. Putting a replacement gauge/float on my list of to-dos.
