Old 01-18-2021, 01:15 PM   #1
skidmarks
skidmarks's Avatar
Default 1940 ford on off ignition lever to 1941 column shift pickup truck swap question
Question is how does the on off lever come apart? The lever tip or knob looks to be either pressed on or is it screwed on?
Dont want to force it.
Swapping the internals from a 1940 passanger car coulmn drop to a 1941 ford pickup column shift drop. ( its different from the 1938 to 1947 pickup floor shift coulmn drop)
Got everything out but the lever and the way the on off plate is the lever must be in 2 pieces
skidmarks is offline   Reply With Quote
Old 01-18-2021, 01:27 PM   #2
skidmarks
skidmarks's Avatar
Default Re: 1940 ford on off ignition lever to 1941 column shift pickup truck swap question
Or, does it not come apart and the badge is dropped over the lever then turned into position for the drive rivits?
Old 01-18-2021, 01:57 PM   #3
Kube
Kube's Avatar
Kube is online now   Reply With Quote
Old 01-18-2021, 02:57 PM   #4
skidmarks
skidmarks's Avatar
Originally Posted by Kube View Post
Got the rivits out and distorted the badge just enough to slip it off so its obvious that the lever is made in two pieces.
After comparing the internal parts, the 40 car is not compatible with the 41 truck coulm shift. Must be a 1 year only unique part all together.
Thats what happens when you leave stuff out in the weather
Old 01-18-2021, 08:41 PM   #5
Ken/Alabama
Ken/Alabama's Avatar
Pulls straight off. It’s on a splined shaft.
File Type: jpg 4B94AD2B-53CF-4BD5-8E67-662BEA87DCED.jpg (32.5 KB, 26 views)
Ken/Alabama is offline   Reply With Quote
Old 01-18-2021, 08:53 PM   #6
skidmarks
skidmarks's Avatar
Thank you
Old 01-23-2021, 02:55 PM   #7
Gregger Rod & Custom
Gregger Rod & Custom's Avatar
Hey Skidmarks,
Here's the info I followed when I did mine
https://fordbarn.com/forum/showthread.php?t=103160
Hope that helps,
Gregger
When you turn on your car, does it return the favour?
Gregger Rod & Custom is offline   Reply With Quote
