Old 01-11-2021, 01:30 PM   #1
Bmoody
Default LED Tail Lamp Bulb
Does anyone know if there is a 6 volt positive ground LED bulb that will plug right into the original tail lamp socket using the original lenses. Hoping to brighten the tail light on a 29 model a.
Bmoody is offline   Reply With Quote
Old 01-11-2021, 01:45 PM   #2
abachman3
abachman3's Avatar
Default Re: LED Tail Lamp Bulb
Yes... Bert's has them, item number A13465L. They were $7.50 each about a year ago.
abachman3 is offline   Reply With Quote
Old 01-11-2021, 01:48 PM   #3
Bmoody
Thank you
Old 01-11-2021, 02:23 PM   #4
redmodelt
redmodelt's Avatar
6 Volt Negative Ground Chassis - Automotive LED Lights
They have a list of bulbs for positive ground but most do not care which ground is used, can be ether.
Old 01-12-2021, 08:36 AM   #5
Badpuppy
Sort by "BA15S" -
https://www.ledlight.com/1129-81-ba1...ightbulbs.aspx
68798-WW (warm white) is what I have
Badpuppy is offline   Reply With Quote
