11-08-2020, 04:51 AM | #1 |
Distributor drive gear shear
1930 Fordor engine stopped turning suddenly last fall. Sat for winter and tried it again this spring. Would not move and cylinders didn't move when put in gear. .. Suspected stuck cylinders so filled them with ATF , waited , tried turning with crank, not much luck.then again..then rocked back and forth in gear and could see cylinders trying to move. Eventually freed up , but found it had been a stuck distributor drive gear and rocking had sheared teeth off.
It looks like it had lost the tab to the oil pump at some time before that - the break was not fresh on the tab. Did not find the tab in the oil pan. Put in a drive gear from another Model A and it seemed to start doing the same thing. Pulled camshaft and it appears fine. No marks on teeth...Timing gear is ok as well. Put camshaft back in and all seems well now but have only turned motor a few times. any thoughts before I put it all back together? Thanks |
11-08-2020, 07:37 AM | #2 |
Re: Distributor drive gear shear
Where did the broken teeth go?
Bob Bidonde |
11-08-2020, 08:08 AM | #3 |
I have seen the oil pump tab sheared off on engines that were sitting with water in the pan that were turned over ---water frozen in the pump preventerd it from turning
11-08-2020, 11:33 AM | #4 |
I just had a case where the distributor shaft, in the distributor, froze in place and locked up the distributor causing the the shaft tab to shear off and the motor to stop.
11-08-2020, 01:04 PM | #5 |
Check your spring and plunger in the timing gear cover,the camshaft endplay actually 'floats',the plunger is under spring pressure.Id check the timing gear as well,basically something stopped when it shouldn't have causing what you are seeing.For a proper repair you need to find the root cause.
11-08-2020, 02:09 PM | #6 |
11-10-2020, 09:43 PM | #7 |
Don't know , there were no chunks...Assumed they were ground up
11-10-2020, 09:45 PM | #8 |
Thanks for the spring idea....It seems in ok shape , but does not have 30-35 lbs of pressure as Andrews manual indicates. I can easily push it in .
Will replace that. |
