Old 10-25-2020, 03:29 PM   #1
alexiskai
alexiskai's Avatar
Default Suggestions on crud removal
Hi folks,
Starting an engine overhaul - new head, valve adjustments, other stuff – and I'm wondering about the best ways to remove crud. Specifically three kinds of crud:
Crud #1: Gasket remnants on both painted and unpainted surfaces. I can scrape it off, but there's always residue.
Crud #2: Brown crud on the surfaces of the water jacket. The coolant looked great when I drained it, but now that I'm taking stuff apart there's a lot of crud around the water pump. Anything I ought to do to flush that stuff out? Is it rust?
Crud #3: Residue in the holes in the block where the head studs went.
Thanks for any suggestions.
Old 10-25-2020, 05:04 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Suggestions on crud removal
I should add, just as a data point, it's always nice when things come off easily. I was able to get the head off simply by turning the motor over with the starter. The studs came out with a little PB Blaster and a stud remover. I was really nervous about it but it went fine.
Bonus: Whoever overhauled this engine last installed double-lock tappets. Must be my lucky day.
Old 10-25-2020, 05:25 PM   #3
Oldbluoval
Oldbluoval's Avatar
Once you scrape it well what about scotchbrite 2-3” discs
Oldbluoval is offline   Reply With Quote
Old 10-25-2020, 07:20 PM   #4
1crosscut
1crosscut's Avatar
A good quality putty knife with a stiff blade that is razor sharp will get the bulk of the crud on the flat surfaces on the head, block and manifold cleaned off. I sharpen my putty knifes on a fine grade wheel on my bench grinder.
Follow that up with a 4" fine grade wire wheel that chucks up in an electric drill. Use a drill that runs on 120 a.c. because most of the battery powered drills don't spin fast enough to make a wire wheel work efficiently. I'm a fan of the Forney brand wire wheels as they seem to last longer and have more bristles.
Most hardware stores have a bulk packages of around 10 small brushes similar in size to toothbrushes. Usually they have a mix of steel, brass and nylon in them. Very handy for getting into nooks and crannies.
For cleaning out bolt holes etc... get a couple sizes of the tube style wire brushes that chuck up in a drill. Once again Forney makes good ones.
I chase all of the threads in the blocks that I work on with taps then blow them out with compressed air.
As far as cleaning grease and grime aerosol brake cleaner is one heck of a solvent that doesn't leave much if any residue. Engine degreaser in an aerosol can leaves a residue that I don't like.
Simple green undiluted is another go to of mine along with acetone for a final cleaning of gasket surfaces and before painting.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-25-2020, 11:26 PM   #5
CWPASADENA
CWPASADENA's Avatar
I would not use Scotchbrite discs on any flat machined surfaces. Scotchbrite has an abrasive component and you will no longer have flat surfaces. This is especially important on the head gasket surfaces which must be flat to seal properly.
Also Scotchbrite is introducing an abrasive in the engine components and you have to be sure everything is absolutely clean and every bit of the abrasive is removed or you can wind up with abrasive inside the engine.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 10-26-2020, 02:26 AM   #6
Synchro909
Synchro909's Avatar
A squirt of brake cleaner and a wipe will clean up the surfaces quite well enough after you scrape of the "lumpy bits".
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 10-26-2020, 04:35 AM   #7
Bruce of MN
Bruce of MN's Avatar
Rather than taps to chase the threads, these should remove less metal and preserve to factory fit.
http://www.langtools.com/sku-2581-26...p-and-die-set/
Bruce of MN is offline   Reply With Quote
Old 10-26-2020, 06:21 AM   #8
David R.
I like a razor scraper handle like you get at paint store for single edge razor blades for removing gaskets on machined surfaces. If you have the babbit out, have it hot tanked. Most shops also have a milder wash they can do that won't harm the babbit. Mine is at machine shop now waiting on the next load to go in the tank. It will be bored .080 over and valve seats refaced, then go to another shop to pour mains and line bore.
David R. is offline   Reply With Quote
Old 10-26-2020, 08:39 AM   #9
alexiskai
alexiskai's Avatar
Ha, I just ordered that exact set last night. All the comments on Amazon were like "I used this set to chase the threads in my engine block."
So I did some shopping and picked up a chisel putty knife and a clean-and-strip disc. I have the brake cleaner. I figure I'll go from least abrasive to most in sequence and see what's needed to get the gunk off.
No comments yet about the crud in the water jacket, any thoughts on that?
Old 10-26-2020, 08:40 AM   #10
alexiskai
alexiskai's Avatar
That would be nice, this overhaul is strictly inside-the-car. That's why I was so excited to discover that someone had put in double lock tappets before I got here.
Old 10-26-2020, 09:50 AM   #11
[email protected]
modela@aol.com's Avatar
The '"farmers' fix" thread chasers are nothing more than an original Model A head stud that has a long lateral grooved slot milled into the threads with a Dremel cut off wheel. Virtually making an original Model A bolt look like a tap. Some cheap HF taps have been known to remove too much material or at the wrong places / angles causing a loose bolt fit.
modela@aol.com is offline   Reply With Quote
Old 10-26-2020, 04:16 PM   #12
Synchro909
Synchro909's Avatar
For that gooey gunk, I run the engine for a while with either a handful of laundry powder in the water but be careful not to go too far. Theat powder contains a foaming agent so the water will become a creamy froth which will not cool properly. Better, I use a couple of dishwasher tablets (no foaming) for a few hundred miles (that might only be a couple of days for me). You'll be amazed at what comes out when you detach a bottom hose (the drain cock is too slow). If things were really bad, I might follow that up with vinegar, which I leave in for about a month of normal use. Be careful when you drain the vinegar - it will stain anything. Flush and away you go.
For built up rust, when the engine is out for rebuild, I have had decent results with a high pressure washer. Once I have all I can get out of the water jacket, I use a short piece of speedo cable in a drill to get in around the hard to reach places and repeat with the HP washer.
Old 10-26-2020, 06:24 PM   #13
vern hodgson
Liberally spray on oven cleaner, let sit and rinse off with water
vern hodgson is offline   Reply With Quote
