09-19-2020, 08:39 PM | #21 |
Re: Loud Noise when car decellerates while i n first and second gears
I had a similar thing happen a few years ago. The noise would only occur when de-accelerating. The cause was found to be that several tabs that connect the engine splash pans to the engine pan had broken. The noise was caused by the tabs vibrating against the pan. I had the tabs welded and made some brackets to better support the tabs.
Tom Endy |
09-19-2020, 10:50 PM | #22 |
The easiest method would be to to upload the file to youtube, then post the link to the file here. Looking forward to hearing it and might help to determine what the sound is.
10-04-2020, 02:43 PM | #23 |
[IMG]file:///C:/Users/Samuel/Downloads/MVI_3625.AVI[/IMG]
10-05-2020, 09:55 AM | #24 |
10-06-2020, 08:50 PM | #25 |
I had a similar problem many years ago. I had an old friend (RIP) go over things with a stethoscope, his opinion was that it was the pinion bearing. We pulled it apart, and he was dead right. Bearing had collapsed, and fortunately did no damage to the crown wheel or pinion. The noise only occurred when decelerating.
1928 Roadster (CA67) 1931 Deluxe Coupe RHD 1931 Victoria RHD Model A's don't leak oil they just mark their territory. |
10-06-2020, 09:16 PM | #26 |
Thread Tools | |
Display Modes | |
