07-09-2020, 09:15 AM | #1 |
39 starter circut
I am having problem with getting starter button to work. I understand button provides ground to wire to solinoid. Does not work even with button grounded directly to batt. If I apply ground directly to solinoid terminal, nothing. If I apply power ( negative ) to term. it works. If button grounds wire at dash, shouldn't it work with term. grounded? What am I missing? Thanks, Mark It is positive ground.
07-09-2020, 09:57 AM | #2 |
Re: 39 starter circut
Did this solenoid work before or is it a new solenoid? If it's a new one it may
be the wrong one. |
07-09-2020, 09:59 AM | #3 | |
1) Repop dash switches are TOTAL CRAP! I can't stress that enough. JUNK! If you have a repop, find an authentic button / switch. 2) Did this circuit ever work properly with the solenoid you currently have installed? Some solenoids (Chrysler?) LOOK correct but internally are not functional with the Ford.
07-09-2020, 10:08 AM | #4 |
You probably have the wrong type solenoid. Check for 6 volts (6 volt system) at the button (center) terminal, if you have 6 volts there, you have the correct solenoid. If you have less than 5 volts there, you have the wrong or bad solenoid.
My guess is that you have a solenoid that requires voltage to the button terminal in order to work. This requires a 2 terminal dash button.
TomO |
07-09-2020, 10:12 AM | #5 | |
07-09-2020, 10:43 AM | #6 |
TomO |
07-09-2020, 10:47 AM | #7 | |
07-09-2020, 11:47 AM | #8 |
You need a solenoid with insulated base, circuit #2.
07-09-2020, 11:49 AM | #9 |
07-09-2020, 12:20 PM | #10 |
I tried an old crusty Ford solenoid an bingo! Works like it should and I learned something new. This site is a wealth of information. Now for a different button, does anyone sell nos. or Nors. ones? Thanks, Mark
07-09-2020, 12:28 PM | #11 |
My brand new repo starter button was very intermittent. Found an original on Ebay for $15, which is a little high, but much better than the other one on Ebay which was priced at $45. No problems since. You might need to brighten the insides of the hole in the dash, where the button clips go.
07-09-2020, 12:39 PM | #12 | |
When you install your "new" switch (dash button) I'd suggest you solder a wire to the body of it. Run that wire to a nearby ground. Rest assured, this makes a huge difference. In every one of my restorations I carefully do this so the "extra" wire can't be detected.
07-09-2020, 12:49 PM | #13 | |
