03-13-2020, 02:53 PM | #1 |
Restored Radiator Shells?
Where can a purchase a re-nickeled 28-29 radiator shell?
"The more things change, the more they stay the same." |
03-13-2020, 08:09 PM | #2 |
Re: Restored Radiator Shells?
local swap meet maybe, go to Hershey this summer, should be some there. or look on the internet but most likely you'll have to repair and restore one then have it plated yourself.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
03-14-2020, 07:00 AM | #3 |
How many hours does it take to restore an original shell?
03-14-2020, 10:01 AM | #4 |
A lot if it's rusty. The metal has to be polished out. If it's pitted, it has to be copper plated as much as it takes to be able to polish the pits back out. The nickle can be plated on after all the copper work is done. The time involved is all the polishing that's required.
Here in the US, plating shops have to meet stringent regulations about containment of heavy metal solutions for plating and the solutions are expensive to maintain. This plus the time involved in the polishing work adds up pretty quick. If you can find a plater that will let you do the polish work then you can save some money but not all of them will do that. A lot of this stuff is done in countries that have few regulations but it's usually for new reproduction parts. Some have good plating jobs and some don't but the thing has to fit like original as well. |
03-14-2020, 10:47 AM | #5 |
I've never dealt with a repro '29 radiator shell that fit well and I've tried several. Ended up finding an original. Perhaps part of the problem has been in the lower-quality repro radiators that we used to be plagued with. Have any members found that their issues with repro shells were actually more of a radiator issue?
03-14-2020, 11:51 AM | #6 |
nickel vs chrome I guess.......... |
03-14-2020, 12:16 PM | #7 |
03-14-2020, 01:12 PM | #8 |
Might be worth a call to Bert's They have a lot of rebuilt parts
03-14-2020, 03:15 PM | #9 |
How long does it take to catch a fish?? . |
03-14-2020, 04:06 PM | #10 |
Try to find the best parts you can find for plating less rework and labor,the better the plate job will be ,I been known to have new old stock parts plated mostly on later cars with die cast chrome.
03-14-2020, 05:55 PM | #11 |
