12-27-2019, 08:53 AM | #1 |
39 rear brake plumbing
Happy Hollidays all!
I’m trying to plumb a 39 rear axel to add juice brakes to my A. A while ago I ordered a T fitting for a 39 from Macs. At least I thought. What I received is a little different from what I was expecting. Please take a look at the photo and advise; A. Did I buy the correct part? B. Where did it mount on a 39? I know I can fabricate a bracket and make it work, but I’m trying to keep things Ford’ish. Thanks, Carl Sent from my iPhone using Tapatalk |
12-27-2019, 09:34 AM | #2 |
Re: 39 rear brake plumbing
B. It mounts on the rear wishbone on the front passenger side IIRC. You should see a threaded hole. From there rear hard brake lines run down the bones and are secured with little clips.
12-27-2019, 09:51 AM | #3 |
This may help. It's a 40 Ford car.
12-27-2019, 09:56 AM | #4 |
Ah ha! ...very interesting fellas - glad I asked.
Thank you, Carl |
12-27-2019, 05:35 PM | #5 |
What year did they start with this part. I thought Ford used this in 1939.
12-27-2019, 06:11 PM | #6 |
