Old 09-26-2019, 09:33 AM   #1
cederholm
cederholm's Avatar
Default rattle-can touch-up paint
Any advice on where to get touch-up paint in stock colors?
Thanks,
Carl
cederholm is offline   Reply With Quote
Old 09-26-2019, 10:21 AM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: rattle-can touch-up paint
Any good auto body supply store. I needed a can of Lombard blue. Took my paint and finish guide and the guys were spot on.
Tacoma Bob is offline   Reply With Quote
Old 09-26-2019, 11:22 AM   #3
Tim Ayers
Good to know.
Old 09-26-2019, 11:59 AM   #4
vern hodgson
Just curious, what was the cost? I was quoted, if I recall correctly around $100.00 and could have been more.
vern hodgson is offline   Reply With Quote
Old 09-26-2019, 12:31 PM   #5
whirnot
whirnot's Avatar
My paint supplier has a one pint minimum which amounts to about 4 cans. I don't recall for sure but I think about $75
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 09-26-2019, 12:46 PM   #6
Tim Ayers
Crud. I just need one can of base coat black to do a steering wheel.
Old 09-26-2019, 04:08 PM   #7
cederholm
cederholm's Avatar
Yeah, TCP Global can mix up a quart but I don't need that much. I though I saw that one of the suppliers sold a limited number of stock colors in spray cans. ...maybe I dreamed it.
Thanks,
Carl
Old 09-26-2019, 04:22 PM   #8
Tacoma Bob
Tacoma Bob's Avatar
Thanks,
Carl
$20.00 for one spray can.
Old 09-26-2019, 04:24 PM   #9
Tacoma Bob
Tacoma Bob's Avatar
On my wheel I went with Krylon Fusion. I.5 years ago and no signs of coming off. Fusion is designed for plastics.
Old 09-26-2019, 04:33 PM   #10
ronn
actually thought it was a bit more then that with shipping............
Old 09-26-2019, 10:08 PM   #11
Mike V. Florida
Mike V. Florida's Avatar
Thanks,
Carl
There was a company called tower paint that did it. With any paint you buy in "stock" colors you have to be sure yours is the same "stock" color. check your car against the national clubs color chips before you order to be sure yours truly matches.
Last edited by Mike V. Florida; 09-27-2019 at 10:02 PM. Reason: Spelling, stock not stack
Old 09-26-2019, 10:19 PM   #12
GerryAllen
$26.00 Canadian for spray can that matched
GerryAllen is offline   Reply With Quote
Old 09-27-2019, 12:39 PM   #13
1931 flamingo
1931 flamingo's Avatar
Lowe's or H/Depot rattle cans, several shades of black available. FWIW
Paul in CT
Old 09-27-2019, 07:54 PM   #14
eagle
eagle's Avatar
A lot of older restorations used whatever color looked close in the paint books. I used hunter green then mixed in some black and some blue until I got it close.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 09-28-2019, 08:29 PM   #15
Shortdog
Shortdog's Avatar
Has anyone ever ran across a Thorne Brown. Also what pant dealers have you been using.
1931 Model A Coupe
Wisdom is not a product of schooling, but of a lifelong attempt to acquire it.
Shortdog is offline   Reply With Quote
