09-22-2019, 07:03 AM | #1 |
8BA oil direction
Getting ready to fire up my freshly rebuilt 1953 8BA for the first time and I want to make sure I have everything correct. I've never run this motor before.
The oil system has been converted to high-flow. Am I correct that the oil is LEAVNG the engine from the outer most fitting (away from the block)? The fitting that shared the port where I have the oil pressure sender? See photo. Thanks, Carl |
09-22-2019, 08:14 AM | #2 |
Re: 8BA oil direction
Sounds good to me.
You should also check flow direction on filter adapter.
09-22-2019, 08:23 AM | #3 |
Awesome! The filter adapter is well marked - thank you!
Sent from my iPhone using Tapatalk |
09-23-2019, 01:23 PM | #4 |
I don't think it is a good idea to use worm hose clamps on a pressurized oil line. You are one clamp failure away from a toasted engine or worse.
09-23-2019, 01:29 PM | #5 | |
Agree^^^ If you want to use plain black hose, use high quality socketless (push-lock) #8 hose and fittings, like those from Aeroquip, that I use.) Last edited by V8 Bob; 09-23-2019 at 01:40 PM. |
09-23-2019, 01:50 PM | #6 |
09-23-2019, 02:14 PM | #7 |
Or if the filter is mounted on the engine it could be hard plumbed.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 09-23-2019 at 02:37 PM. |
Thread Tools | |
Display Modes | |
