Old 10-06-2018, 08:18 PM   #1
Challie
Default Gear lube in a banjo rear
What weight gear lube should I use in a 1937 ford banjo rear? The stuff that came out was REALLY thick.
Challie is offline   Reply With Quote
Old 10-06-2018, 08:27 PM   #2
Bursonaw
Bursonaw's Avatar
Default Re: Gear lube in a banjo rear
Original was a straight 140w gear oil.
I have been using 140 multi weight gear oil with no issues.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 10-07-2018, 02:42 AM   #3
Talkwrench
Talkwrench's Avatar
85 _ 140 mineral will be fine if you're in a moderate climate.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 10-07-2018, 06:40 AM   #4
JSeery
JSeery's Avatar
I have been using 140 multi weight gear oil with no issues. Sent from my iPad using Tapatalk
There is actually no such thing as 140w, it would be SAE 140. The "W" is for Winter in the rating system and the most common highest "W" rating for gear oil is 85w. The term "weight" is confusing, it is actually the viscosity rating. Oil/lubes viscosity are tested at two different temperature ranges, a straight viscosity oil/lube is rated at 100 deg C and a Winter rating (W) is rated at -30 deg C. A multi-viscosity oil is good to use where temperature vary.
Old 10-07-2018, 07:20 AM   #5
doghair3
Has anyone used the Lubriplate products in the rear end or the transmission? In particular the SPO-277 SAE Gear Oil 140.
https://www.lubriplate.com/Online-St...rt-bottle.html
doghair3 is offline   Reply With Quote
Old 10-07-2018, 07:30 AM   #6
JSeery
JSeery's Avatar
Is there a reason you would want to use it? Doesn't seem like the best gear lube to use in a V8 application to me. IMO a modern gear lube would be a better option. Something like an 85w-140.
Old 10-07-2018, 09:40 AM   #7
doghair3
I've talked with guy's who have cars other than Fords and they swear by it. First they say the viscosity is much better and it has much better lubricating properties not to mention it most closely comes to the original stuff. I'm also told that transmissions shift much better.
Old 10-07-2018, 09:49 AM   #8
JSeery
JSeery's Avatar
Little hard to believe in a rear axle, the supplier doesn't even recommend it. And the price is a little ridiculous. May be repackaged GL1. Not something I would use, but if your sold on it go for it.
Old 10-07-2018, 10:28 AM   #9
doghair3
Pretty much I am. I'm a believer you only get what you pay for.
Old 10-07-2018, 07:46 PM   #10
TomT/Williamsburg
TomT/Williamsburg's Avatar
With the way I drive my avatar every year I change my rear end fluid every year. For some, that may seem too often - but I am not having any issues either. At the speeds and distances I go, that rear is working alot harder than it was intended/designed for. Cheap insurance in my book. I usually run 85-140 or 75-90. Whatever I can get at Advance by Lucas .....
TomT/Williamsburg is offline   Reply With Quote
Old 10-07-2018, 07:56 PM   #11
deuce_roadster
deuce_roadster's Avatar
I have been happy with Redline products, they make a product that doesn't harm the yellow metal in trans, I think it has MT after the Viscosity for "manual transmission". I use it in both trans and differential, both stock and Columbia with never an issue.
Old 10-07-2018, 08:03 PM   #12
Tinker
Tinker's Avatar
It's the old oil debate in action. again.
Yes there is oil with higher weight then the 80-90w stuff.
Steam cylinder oil "mobile 600w" is probably as close to the original weight that you can get. Probably around 140-160. It has less additives as it mostly used for cooling equipment and compressors. Available at depo house in 5 gallon buckets.
https://www.practicalmachinist.com/v...ght-oil-90978/
You'll be fine with the 90-140w stuff
Old 10-07-2018, 08:12 PM   #13
Tinker
Tinker's Avatar
Quick search for ya Challie
Read this...
https://www.fordbarn.com/forum/showt...ear+oil+weight
Just a quick note for new people. On the bar above there is a search function with an advanced link. I know not everything is archived but it might be quicker to give it try, then wait for a response. Read up. Just a thought.
