Old 10-20-2017, 02:17 PM   #1
kbinde2
kbinde2's Avatar
Default LH Thread
Looking for a source for 6-32x3/8" screw or threaded rod/nut with left-hand thread. I've had an armature for a horn faced, drilled and tapped. Now to get the wafer disc back.. I'm stuck.!
Anybody have metal lathe skills.?
kb
kbinde2 is offline   Reply With Quote
Old 10-20-2017, 02:26 PM   #2
CarlG
CarlG's Avatar
Default Re: LH Thread
Try:
https://www.mutualscrew.com/departme...-rod-13036.cfm
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-20-2017, 03:31 PM   #3
kbinde2
kbinde2's Avatar
Not much luck with commercial suppliers.. I guess I'll have to have it made.!
Old 10-20-2017, 03:40 PM   #4
SeaSlugs
SeaSlugs's Avatar
can you find a small enough turn buckle? one side is left hand threads...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 10-20-2017, 03:55 PM   #5
slammin
slammin's Avatar
You can buy a left hand thread and die and make your own parts.
MSC lists the following:
OSG 6-32 left hand tap 01559053 $8.56
Vermont Tap & Die 6-32 left hand die 33163312 $10.85
Both are quality tools not Chinese crap
MSC shipping charges are reasonable.
slammin is offline   Reply With Quote
Old 10-20-2017, 05:49 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
Have you tried McMaster-Carr. They have left-handed fasteners.
Old 10-20-2017, 08:41 PM   #7
Fullraceflathead
Fullraceflathead's Avatar
MSC or McMaster Carr are great places.
Most large cities will have a Machinist Supply and they will have the items you want also.
Any Machinist with a Lathe can cut left handed threads but the Hourly rate will make it not wanted. Most are at least $100.00 minimum.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 10-20-2017, 08:52 PM   #8
Quigley1930
Quigley1930's Avatar
McMaster-Carr shows a socket head screw #91670A146 6-32x3/8. the price is $11.69 which may be each or 100. Call to find u.
Sewall
Quigley1930 is offline   Reply With Quote
Old 10-21-2017, 03:46 AM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Sewall
I'd try Fastenal first. Even if they have to order it, it will be cheaper.
Old 10-21-2017, 11:08 AM   #10
100IH
Consider using standard threads for the repair. It will work.
100IH is offline   Reply With Quote
Old 10-21-2017, 11:19 AM   #11
rogerkb1936
rogerkb1936's Avatar
far as I know, all the horns except s/w use r/h threads and they work just fine. you are not the first to strip the l/h threads on a s/w.
rogerkb1936 is offline   Reply With Quote
Old 10-21-2017, 11:39 PM   #12
Mike V. Florida
Mike V. Florida's Avatar
Have you tried A and L?
Old 10-22-2017, 10:54 AM   #13
katy
katy's Avatar
Does it need to be LHT? If not, how about drilling it out and rethreading to 8-32?
Old 10-22-2017, 10:34 PM   #14
Ray in La Mesa
I drilled & tapped a SW armature with 8-32 and used JB Weld to lock it. All other thread lockers came loose with ratchet vibration. If I have to remove I'll just heat the screw head a bit to break down the JB Weld but not enough to hurt the armature windings.
Ray in La Mesa is offline   Reply With Quote
