Old 06-10-2017, 04:17 PM   #1
bo8109b
bo8109b's Avatar
Default Contaminated gear oil
Changing the transmission gear oil in my '48, noted microscopic steel flakes in the old oil. Total amount was less than a half thimble full. No operational problems. Oil not blackened. Is this a sign of normal wear?
bo8109b is offline   Reply With Quote
Old 06-10-2017, 04:44 PM   #2
Karl Wolf
Karl Wolf's Avatar
Default Re: Contaminated gear oil
I would be tempted to take a look inside. If you don't, do put in a magnetic drain plug.
I put one in the fill hole (also)- the thought is that one could pull it without draining the oil.
Karl
Karl Wolf is offline   Reply With Quote
Old 06-10-2017, 10:29 PM   #3
Drbrown
Drbrown's Avatar
I hope/assume you haven't changed the Tranny in a long time. If its been a short time I'd be concerned about that much ground-metal in a short time period.
Drbrown is offline   Reply With Quote
Old 06-11-2017, 08:32 AM   #4
JSeery
JSeery's Avatar
What gear oil were you using?
Old 06-11-2017, 12:31 PM   #5
bo8109b
bo8109b's Avatar
Using GL-4 85W90. Been in there a long time. Are there magnetic drain plugs available to fit a '48 transmission?
Old 06-11-2017, 03:10 PM   #6
Tinker
Tinker's Avatar
Buy some earth magnets off ebay or something. You can put them on your engine oil plug and gas tank as well if you like. Very powerful and pretty cheap. The little disc ones are great. Pops right on the outside of the plug and I've never had one come off.
http://www.ebay.com/sch/i.html?_from...gnets&_sacat=0
