Old 12-12-2015, 07:29 PM   #1
some mech 3
Default Difficulty Removing an outside door handle on a 1931 Standard Roadster
I have the cardboard panel removed from the door and the latch is exposed, but I cannot see any pin or anything else to remove in order to pull out the handle. I will be very appreciative if someone offers the answer. Thank you very much.
Some mech 3.
some mech 3 is offline   Reply With Quote
Old 12-12-2015, 07:58 PM   #2
Bob C
Default Re: Difficulty Removing an outside door handle on a 1931 Standard Roadster
I assume you have removed the inside handle.
Bob
Old 12-12-2015, 08:16 PM   #3
MAG
MAG's Avatar
As suggested remove the inside handle. Next, remove the two screws on the bezel on outside of the door. Pull the handle out.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
