Old 05-27-2013, 10:36 AM   #1
solidaxle
solidaxle's Avatar
Default What generator do I have?
Stamped 8BA-D. I think this is the date code A-1-1, correct? Has two brushes and a field, ground and armeture connection.
Second part of the question . Can I install a generator fan mounted pulley on it?
solidaxle is offline   Reply With Quote
Old 05-27-2013, 01:19 PM   #2
John R
Default Re: What generator do I have?
The "8BA-D" identifies it as to type, not date. This is a common 35 amp, 6 volt unit used on both V8 and 6 cyl from 48 thru 51. To run a fan off the front, you need to modify the existing pulley. None of the early (pre-1940) fan-mount pulleys are very suitable for use with the late generators because of differences in front plates and armatures.
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 05-28-2013, 03:03 AM   #3
solidaxle
solidaxle's Avatar
Do all generator pulley's interchange after 1940, to 1953? I don't see how I could modify the existing without changing the assembly out.
Old 05-28-2013, 08:51 AM   #4
John R
40 to 48 generator pulleys mount to the armature shaft in a different way than the 49 -53 pulleys. The 40-48 have internal threads, thread onto the armature shaft and are retained by a snap ring. The 49-53 are not threaded, but have a Woodruff key and are retained by a lockwasher and nut (more or less the same as the pre-39 generators). Also, the 40-48 pulleys are not fan-drive.
To modify the existing 49-53 pulley to drive a fan, a fan mounting piece has to be fabricated and welded to the pulley. PM me for more details on this modification.
Old 05-28-2013, 10:40 PM   #5
Karl Wolf
Karl Wolf's Avatar
I'm running a stock Ford pulley -with a fan- on a 12V (1956 up) armature... All stock Ford parts, found at swap meets. So, it's possible. The pulleys I've used thread on...
I would be hard pressed to speak to the exact parentage of the parts, though.
Karl
Karl Wolf is offline   Reply With Quote
Old 05-28-2013, 11:54 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
What you want to try is a pulley from 37-39 2 brush generator, there are several diameters -I know they will fit the 42-48 style, have never tried on the 8ba type held to the bracket with a band ---what you want to look in is the "green book" there will be pictures, there may be some versions with the threads in the pulley like 42-48, but most are held on with a nut.
