Old 12-23-2020, 11:49 PM   #21
old31
Default Re: Topics one should cover in a "new head" walkthrough video
Jack brings up an interesting question. How many are using a 6.1 or higher head feel you have to go with a mechanical advance?
Alex is using NU-Rex. Any others, feel you have to go mechanical?
With my 6.1 Snyder, just once and a while do I have a knock. If I do, I adjust it.
I kinda look at the Nu-rex as just one more failure point.
old31 is offline   Reply With Quote
Old 12-24-2020, 05:49 AM   #22
Bruce of MN
Bruce of MN's Avatar
I'm using the stock manual advance with my 6:1, but it does require attention in hilly country. It becomes habitual with driving it several times a week and hour or more long trips.
Old 12-24-2020, 07:52 AM   #23
alexiskai
alexiskai's Avatar
I got the Nu-Rex a couple of years ago (when I still had the stock head) because my wife drives the car occasionally and I wanted to reduce the number of things she has to keep track of.
Old 12-24-2020, 09:54 AM   #24
Plainsman30
I had a blown head gasket soon after my motor was rebuilt. I replaced it, and soon had a scored piston. When we took the engine back apart, I noted the water hole passages were not drilled all the way through the casting on the new high compression head. I am not sure if this was a contributing factor to the problems or not, but I asked the vendor to send me a different head. It was better, but still did not have the water holes drilled out properly. although it was different water holes than the first head. I then had 3 heads on my bench, and the only one with the water holes drilled out properly was the original stock head. I drilled/ chased out the holes myself on one of the high compression heads, which is not hard to do and have not had any additional problems.
Mike
Plainsman30 is offline   Reply With Quote
Old 12-24-2020, 09:59 AM   #25
alexiskai
alexiskai's Avatar
Huh. I would be interested in covering this in the video, but I'm not sure what to tell folks to look for. Do you have a pic of a bad head?
Old 12-26-2020, 06:54 AM   #26
old31
Plainsman, please tell us whos head you are using so that we can be aware of the holes.
Old 12-26-2020, 07:58 AM   #27
1crosscut
1crosscut's Avatar
Something that I do to protect the paint on a newly painted head while going through the torque in process is to put an o-ring around each head nut to keep the socket from marring the paint.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 12-26-2020, 09:24 AM   #28
alexiskai
alexiskai's Avatar
He wouldn't say, but he sent me a picture of the face of the defective head and it looked like a 5.5 head. Can't be sure who made it. I think we should exercise this kind of diligence no matter who the source is.
Old 12-26-2020, 11:53 AM   #29
Jack Shaft
Are you talking about the 1/4" holes? Did #4 piston score?.Its difficult to cite cylinder head water flow for piston scoring due to the water jacket on the block side controlling cylinder cooling. The major cylinder head water flow ports are in the casting mold, irregular shapes.
Old 12-26-2020, 11:30 PM   #30
Plainsman30
It was the 1/4 hole between pistons 3 and 4 that was not drilled out fully into the water jacket. On my second HC head, a different 1/4 hole was not drilled out.
Back 2 pistons (3 and 4) were scored. The scored areas face each other and both face the divider between cylinders 3 and 4 where the water hole is located.
The scored pistons were just the start of a long, very expensive, and frustrating problem. I don't know for sure what all caused the problem, but I recommend checking the water holes the head to be sure they are open before installation.
Mike
Old 12-27-2020, 12:13 PM   #31
Jack Shaft
Piston to bore clearance is critical,too tight and the piston will score.Tough break Mike..
