Old 09-19-2020, 08:39 PM   #21
Tom Endy
Tom Endy's Avatar
Default Re: Loud Noise when car decellerates while i n first and second gears
I had a similar thing happen a few years ago. The noise would only occur when de-accelerating. The cause was found to be that several tabs that connect the engine splash pans to the engine pan had broken. The noise was caused by the tabs vibrating against the pan. I had the tabs welded and made some brackets to better support the tabs.
Tom Endy
Old 09-19-2020, 10:50 PM   #22
GRutter
GRutter's Avatar
Originally Posted by some mech 3 View Post
To all contributors: I have made an audio tape of the decelerating noises. However, I need very explicit directions on how to upload the file from my pictures and get the tape to you. I look forward to hearing from you.
The easiest method would be to to upload the file to youtube, then post the link to the file here. Looking forward to hearing it and might help to determine what the sound is.
GRutter is offline   Reply With Quote
Old 10-04-2020, 02:43 PM   #23
some mech 3
[IMG]file:///C:/Users/Samuel/Downloads/MVI_3625.AVI[/IMG]
some mech 3 is offline   Reply With Quote
Old 10-05-2020, 09:55 AM   #24
katy
katy's Avatar
Old 10-06-2020, 08:50 PM   #25
Bick in New Zealand
Bick in New Zealand's Avatar
I had a similar problem many years ago. I had an old friend (RIP) go over things with a stethoscope, his opinion was that it was the pinion bearing. We pulled it apart, and he was dead right. Bearing had collapsed, and fortunately did no damage to the crown wheel or pinion. The noise only occurred when decelerating.
1928 Roadster (CA67)
1931 Deluxe Coupe RHD
1931 Victoria RHD
Model A's don't leak oil they just mark their territory.
Bick in New Zealand is offline   Reply With Quote
Old 10-06-2020, 09:16 PM   #26
ursus
I experienced this problem with a rear axle in which the pinion bearing retainer nuts had come loose. The result was a driveshaft that was no longer fixed in place and was able to move back and forth and hammering forward upon deceleration.
